Question about Amana Dryers
I have a 3 prong plug that I need to convert to a 4 prong plug/chord. The new chord's wires are color coded but the old ones are not. How do I know which wires go where?
    Genius:
  • 1,073 Answers
Black to outside screw
red to outside screw
white to middle screw
green to a screw on the cabnet
Posted on Jun 10, 2008
Convert 3 wire plug generator to 4 wire plug cord
First verify that the voltage is the same. It sounds like you have a single phase system which is 2 voltage circuits and 1 neutral. The 4th prong will be the ground. To do this properly you will need to get a new 4-wire chord for the generator with a cap that matches the one for your house. On the Generator side, the 4th wire will attach to ground.
Oct 04, 2017 | Dryers
Where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
Jan 23, 2015 | Furniture
I need to install a 4 prong wiring plug on the this unit. However the old thre prong wiring it not color coded to show where to replace the new 4 prong wires.
Good Morning. Looking at the terminal board. Left to right. Left, black wire, middle, white wire, right, red wire. Green wire that's left, find an external screw that screws into the frame and attach wire here. Hope this helps and have a good day.
Feb 08, 2011 | Dryers
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Wrong power chord I need to change from 3 prong to 4 prong.
The following link describes how to convert from a 3-prong appliance cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The difference is the way the Neutral (White wire) is configured. On a 4 wire configuration, the neutral is independent of the ground (Green) wire. Which means you DO NOT ground the white wire. Ground gets attached to the equipment cabinet or appropriate ground lug.
NOTE: This is for United States standard wire code. If you live outside the US, your wire color coding will differ. Please let me know if this is the case.
Let me know if you have any questions. I hope this helps you.
Jul 12, 2009 | Kitchen Ranges
4 prong what colors go where
match the colors of the wires to the plug always, the fourth wire you can just leave open as it will not make a difference for your particular instance.
May 10, 2009 | Crosley CDE6000 Electric Dryer
How do I change from a 4 prong wire to a 3 prong wire on a kenmore h34t washer
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
These steps will work for nearly all appliances that require a 220-240VAC power cord conversion. The power cords are usually rated at 250VAC, 30 amps, and are carried by any hardware store or appliance parts retailer.
ADDITIONAL NOTES:
1. If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
2. On some newer appliances, it is REQUIRED that you use a 4-prong plug in order for the timer or clock circuits to function properly due to the way they are configured. Refer to your owner’s manual for the correct recommendation. Even if you currently have a 3-prong receptacle, you still may be required to upgrade to a 4-prong if you encounter this situation.
3. In many circumstances, new appliances are NOT sold with the power cord due to the various power configurations in homes. Always refer to the contents description on the shipping container the appliance comes with to see what additional items or tools may be required for installation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
New Wire Not Color-Coded
when you line up the new cord have the cord point down and the cord is ok to install. either of the outside wires go to outside terminals . th important thing is to get the middle wire to the center terminal
Dec 29, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
I've since moved and in the new house the dryer cord had a 3 pronge plug. The one that I need in the new house is a a 4 pronge plug. I purchased one, took off the 3 pronge plug without looking at the...
Yes, it does matter which color wires are connected. If connected wrong, you may injure yourself and/or destroy the dryer. The following link explains how to convert your dryer plug:
Let me know if you have any further questions. I hope this helps you.
Aug 07, 2008 | Dryers
Dryers Logo
70 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
