Question about Amana ABB1927DE Bottom Freezer Refrigerator
Kenmore refrigerator 26' side-by-side Model 596.52673200
Could some one please let me know how to replace thermostat on this refrigerator (Kenmore refrigerator 26' side-by-side Model 596.52673200)? Thanks.
    Problem Solver:
  • 16 Answers
On the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Posted on May 13, 2009
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: The refrigerator side is not cold.
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Aug 27, 2009
Testimonial: "The information was helpful and solved my problem. I also learned something about the operation of my refrigerator. Thank you"
woodchuck789
  • 4070 Answers
SOURCE: How to check defrost timer on Kenmore side by side
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check , defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Posted on Sep 08, 2009
Testimonial: "Thank you"
Milleniumboy
  • 106 Answers
SOURCE: Last month I had a problem with my Kenmore
HELLO,
The non cooling is brought by the Expanded and Rapidly cooling air which keeps it cool is being blocked by the ice, and simultaneously being condensed by the temperature difference... The ice blocks its path and forms frost...but there is obviously air coming in contact with it...The problem is typically air is leaking in the fridge somewhere, make sure doors shut tight after cleaning the frost in the back panel...this should do it...:)
Posted on Sep 09, 2009
The refrigerator part is 60 degrees and the freezer part is blow 20 degrees, I found the cond fan motor locked up not running, I have cleaned the condenser coils, replaced the cond fan motor but the...
Please follow these steps.
Keep temp setting at 5 degree. Check defrost timer, thermostat and frost heater are working properly. Call repairman to check above all. Thanks.
Feb 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
Both defrost heater/timer replace, still frosts up in the back after about a week.
If you did not replace the defrost thermostat then that may just be the problem. I will help you if you like, please let me know. Also I need to know the Kenmore model number to see if it falls under some that were sold to Sears by LG and Maytag. I am looking for a number like this for example 795.7756400
Thanks, Sea Breeze
Oct 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side kenmore refrigerator not cooling.Tampa FL.
HI thanks for your question. the problem you are having is that its not going into the defrost cycle. its not an expensive repair, probably $ 150. 00. unless you have the proper meter to check i would call a tech . but its more likely the defrost timer. or the defrost thermostat. thanks the appliance doc. please rate my answer. thanks.
Oct 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge not holding the temperature
hi thanks for the question yes it is the thermostat go and buy one they will give you instructions on how to install if not come back here and we will help thanks the appliance doc
Sep 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator stops cooling
You have a defective ( Bad) thermostat that controls the temperature. Have the thermostat replaced.
Jun 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
757 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
