Question about Panasonic PV-GS150 Mini DV Digital Camcorder
Recording and playback problems
My camcorder, which was working perfectly the last time I used it, now plays back known good tapes with horizontal blue stripes and noise. I have used a head cleaner multiple times with no effect. Also, if I try to record anything all I get is a blue background and erratic or nonexixtent tape counter. Panasonic's answer, as expected, was "give us $200 and we'll fix it".
  • 2 more comments
  • TMcDonald Jul 06, 2008
    I have the same problem - have you found a fix to it yet? Thick blue lines during playback, distorted audio, blank blue screen during taping.....please help!
  • TERRY_FISHER Aug 30, 2008
    I have the same problem with the bright blue stripes on playback. Yesterday the camera was fine. This morning I have blue stripes. The camera was not dropped, bumped, or anything.
  • dchu Sep 17, 2008
    I have the same problem. I used a tape cleaner and nothing. They want to charge me $261 to look at it. I am very upset does anyone have any suggestions???
  • mkoverdan Sep 23, 2008
    My camera is doing the same thing. Blue lines during playback, used a head cleaner multiple times and nothing has worked. Called to see cost of repair and they said $261 - outrageous!
    Others seem to have the same issue. Can anyone help me?!
Profession diagnosis was that the drum is out of round and cost of repair prohibitive, so I bought a new Panasonic PV-GS500 with a service contract this time! I had actually dropped the GS-150 when it was fairly new and the fall was cushioned by landing on the battery, so I did get a couple of years of good use from it.
I continue to use it as a still camera -- Amazingly, it takes great stills (better than my GS500). Unfortunately, my husband lost the lens cover (and the lens is kind of scratched now), so I would like to replace these parts if I can do so at a reasonable price. Thanks.
Posted on Jul 13, 2008
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Purple and green digital lines across film
One of the units is not making good interchange in recording (CAMCORDER) or (PLAYBACK) DSR11 deck either buy or get a known good recording to isolate the bad unit. Camcorders are notorious for loss of interchange as the cassette compartment wears out the scissors jack elevator gets sloppy and changes the angle of attack on the drum and wellah a tape that only plays back in the camcorder.
Jan 18, 2008 | Sony DSR-11 DV / Mini DV VCR
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
394 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
