Question about Pioneer VSX-D608 Receiver
Now sound after poweer failure
I was watching a movie last night when we had a power failure. When the power came back, I had no sound in my speakers. I plugged in headphone and I hear the signal - but very low volume. Can you suggest if there is something I need to reset due to the power failure? Is there anything else I might check?
Thanks, Rich
    Genius:
  • Pioneer Master
  • 1,550 Answers
Maybe the audio amplifier IC go on short circuit,and you gotta send to repair service to get fixed.
Posted on Jun 10, 2008
Sanyo DP47460 intermittent sound
Check its speaker. If it is found OK, check and replace the damaged component/s in audio output section circuits.
Jul 22, 2012 | Sanyo DP47460 Diagonal HDTV
I have a VSB200. It worked until last night. No sound coming out of it now.
I have the same sound bar and in the middle of watching a movie, it just stopped working. I came to the conclusion that it was the optical hookup on the back of the speaker that had an issue. The problem with the entire situation is that I had only owned the sound bar for around two to three weeks and only watched around four movies on it until this problem. Either a fluke or bad quality. Check your optical connection if that is what you have it hooked up to.
Apr 28, 2011 | Vizio VSB210WS Soundbar
I have a Yamaha Rx-V363 AV receiver. Last night while watching a Movie, it automatically switched off. from then Onwards, whatever way i try, i cant switch it On. I tried to remove all wiring to my Home...
The unit probably experienced a power supply failure, and will have to be troubleshot. You should contact Yamaha to find an authorized repair facility near you. Here's their support site:
http://usa.yamaha.com/support/
You also contact a local repair shop. Make sure you get an estimate first, since repair can be costly.
Good luck, and hope this helps.
Feb 23, 2011 | Yamaha RX-V363 Receiver
I found an Astar portable dvd player with only the battery charger attached months ago and nobody claimed it. I used it night before last and watched a whole movie, last night I watched a movie and it just...
Possibly you just need a new power supply/battery charger. There is nothing "magic" about the original power supply. Take the player into an electronics supply shop. They should be able to look at it and match
Voltage In Voltage Out Power requirement (milliWatts or Watts) Connector Type Polarity (center of plug positive or negative)
Oct 10, 2009 | Astar PD-3010 Portable DVD Player
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Laptop Sound Problem - Muffled!
The DVD players in laptops are asked to do alot. First I would try is that movie on another DVD player - wtch closely to see or here any abnormalities in the the same location. Your DVD laptop player may very well be bad. Better to get it checked out under warranty. When you take it or send it make sure you tell the tech where exactly the movie goes muffled and if you can send or give the movie to the tech.
Mar 20, 2009 | HP G60-120US Laptop
No sound and on/off button is on but not the light
Lol. Okay glad to hear that. I'm here if you have anymore problems.
Jan 03, 2009 | HP P5302M Computer Speakers
Pioneer VSX-D608 Receiver Logo
89 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
