Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Panasonic Viera TH-37PX8B Green Screen Whe...
By simon05 on Jun 10, 2008
Hello I have recently purchased a Panasonic Viera TH-37PX8B. Have set it up and it works fine with sky and normal analogue aerial but when I come to turn on the DVD/VCR player the screen turns to a green colour but it still functions with sound. Have tried checking the way it is all connected and it seems fine, any ideas?
Comments:
Jun 10, 2008
- Thanks 4 reply. I had a scart lead from DVD to TV. Should I just be using a single cable from the yellow DVD output to the yellow TV input?? Will I still get sound and a picture?? Thanks
Jun 10, 2008
Same Problem
May 04, 2009
-   I have the same problem exactly. Might try getting some new leads instead of using the scart lead as suggested. -   jan-ray
Mar 28, 2009
-   the same problem -   Guest
Jan 19, 2009
-   Same problem for me, I even went with my DVD player to the panasonic dealer and we tested together on 2 different plasma TVs over the SCART cable. The problem only occurred on the panasonic viera, not the other plasma TV ( think it was a samsung ). Waiting for an official answer from panasonic now ...
-   wim_038
Nov 24, 2008
-   I have the same problem but all the white in the picture comes through pink. Sky and Wii box work fine-   madsw
Nov 08, 2008
-   The problem is certainly the Panasonic LCD TV. My trusty dvd player also has the serious 'green'; problem with the purchase of the Panasonic. The player worked fine on my old TV and is also excellent with a Sony LCD TV. I do not want to splash on a new DVD player as I have a PVR. My Philips DVD apart from the scart has only 4 sockets, a CVBS, a coaxil, and left & right audio out, in comparison to Component, Y, P8, and >R on latest models. Can anyone please help? By asking all round, I am told the only realistic answer is my Philips DVD player and the Panasonic TX-32LXD85 are simply incompatible, how realistic is that. HELP??-   derby747
Solution #1
posted on Jun 10, 2008
Somewhat Helpful)
Abrsvcs
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1843 votes
This sounds to me like you have connected a "composite" signal to a "component" input, specifically the green input. Make sure that you have the correct cable. A composite cable will contain only 1 video cable (yellow). The component one will have 3 for video (green,red, blue).
Dan
Comments:
Jul 13, 2008
- If you have connected the correct color of cables (eg. Yel to Yel etc.), then the next item to check is in the TV itself. A composite signal (Yel) contains information about all three colors (Red,Blue, Green) and the TV will decode the single video signal in to the component parts that then are processed separately. If you are getting just Green, then either the decode process is not working properly or the Red and Blue signals are being lost. One thing that would help is to know the timeframe during which the set turns green. If it is green all the time, then the decode section is suspect, if it takes a while, it is possible that there is a bad connection that is heat related or a defective component also heat sensitive.
One other thing to check is to be sure that the DVD Is set to output COMPOSITE signals rather than COMPONENT. Some units use the same set of RCA output jacks for both options. The output may need to be set within the video setup menu of the DVD.
Please update this with the info requested above and I'll try to track this down.
Thanks,
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 05, 2009
Helpful)
nomad_daly
Rank: Apprentice  Televisions & Videos  Expert
Rating: 94%, 4 votes
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Dec 21, 2008
Helpful)
bart54
Rating: 88%, 2 votes
Had the same green screen problem with my Panasonic TV when connecting a new DVD recorder using a scart lead - even down to pulling the lead till its almost falling out!
Reading on the forums it seems to be a common Panasonic fault.
Instead of using a scart for output I used the Component connections. Red, blue and green for the video signal, and red & white for the left & right audio.
Use the setup menu on the DVD and set video output to progressive.
To watch output from the DVD I now just select 'Component' on the TV from choice of AV inputs. Doesn't switch automatically like it would with scart connection, but everything works fine.
It may not be the solution for everyone, but it works for me, and it's a lot cheaper than buying a new DVD !
Was this helpful?
Yes
No
Solution #4
posted on Nov 01, 2009
Not Rated)
Damog7
Rating: 0%, 0 votes
Solution 2 is the winner, well done and thank you, it took a matter of seconds.
D
Was this helpful?
Yes
No
Solution #5
posted on Dec 31, 2008
Not Rated)
p-farrelly
Rating: 0%, 0 votes
sky hd box turns wheni try to play some of the sky games, but not all of them do it.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Have a Toshiba 42h83 that has a blue and yellow "shadow", any suggestions?
Answer
tv will not power up properly.??? the light will go from red to green for a quick second then back... (More)
Answer
my 52 sony brav hdmi are not working the pc will run and the ps2 will! what do i do.
Answer
3'' solid black vertical line just left of centre on my 50'' panasonic plasma can i get rid of it
Answer
flashing and unlegable screen information when changing channels
7 Other Users Have The Same Problem - Continued
Comment by slamdunkcjp, posted on Jul 07, 2008
Also have a Panasonic TV. Connected the sky box to the DVD recorder, and then DVD to TV, as I have no normal aerial signal to connect at moment.
Exactly the same happens when I turn on the DVD player, the screen turns green. If I fiddle with the scart in the back of the TV I can sometimes correct it, but not ideal as scart lead is only just hanging in.
Comment by dennis 1945, posted on Jun 25, 2008
when switching to dvd i get agreen screen the dvd still works but with agreen picture have checked cables seem to be ok is there away to tune in dvd to tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
