Question about HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
Computer Compaq presario 1247 will not complete windows download, says hard drive not detected
If you have the original Windows operating system boot disk or can get one via download, try booting off that. If the computer then runs OK, you will need to attempt to format the hard drive.
Posted on Jun 29, 2008
Computer do not detect the hard drive
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 30, 2012 | Compaq Presario 2170US Notebook
Opertaing system not found
Your hard drive may be faulty, this is why the Windows operating system not found.
Go into the BIOS and see if the hard drive is detected, if not reseat the hard drive and boot up again.
If the Windows operating system not found then most likely the hard drive is faulty and to get the Notebook working again, replace the hard drive, install Windows on the new hard drive plus the Compaq Presario 1692 device drivers and your programs.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
Jul 14, 2011 | Compaq Presario 1692 Notebook
Compaq presario v6000 computer does not detect hard drive storage
The hard disk may be faulty or it just needs reseating to make proper connection.
Reseat the hard drive and boot up your laptop. If it does not boot up then go into the BIOS configuration to see if the BIOS detects the hard drive.
If the BIOS deos not detect the hard drive then most likely it is faulty. In this case to get your laptop working again, replace the hard drive and install Windows on the new hard drive plus the Presario's device drivers and your programs.
Jun 21, 2011 | Compaq Presario Notebook
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
When I try to put XP on my Compaq Presario C500, it cannot find the hard drive and will not try to load it. I have already done a diagnostic on the hard drive and it is working perfectly. What can I do?
I take it that the hard drive is a not the normal IDE but rather a SATA (newer technology) drive. Inthat case you can in some cases change the Hard drive setting in the CMOS setup from ENHANCED to IDE-MODE under STA drives. That causes the installation to detect the drive as an 'IDE" drive in which case it then can install windows. The normal windows installation cannot always detect SATA drives while installing and then reports that there is NO drive attache to the computer
Jul 06, 2009 | HP Compaq Presario C500t Notebook
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
I have a crashed compaq presario, 1247-model #1456vqlin,laptop.
do you have a copy of windows xp with license key if so that will suffice then all you have to do is go to and download the drivers from there
Mar 16, 2009 | HP (158800-001) for Compaq Presario 1246,...
Windows not detecting hard disk
rhel ? redhat linux ???
be that as it may if that happens to be a desktop computer... is it a sata hard drive ??
Dec 16, 2008 | Compaq Presario C700T Notebook
1247 compaq presario
Here is a link to the 14.8v rechargeable replacement here Compaq presario laptop battery , this is for the presario 1200 range of batteries including the 1247
Oct 10, 2008 | HP (158800-001) for Compaq Presario 1246,...
Compaq presario 158793-001 motherboard
Hey Mike
Go back and check the fine cabling that connects LED indicaters to motherborad. There's got to be a small cable you forgot to plug into the board to feed back poer state. Take your time and check everything twice.
Dec 12, 2007 | HP (158800-001) for Compaq Presario 1246,...
HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan Logo
98 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
