Question about Kenmore 62622 Microwave Oven
F9 error My Kenmore began displaying this yesterday. Assuming it is the magnetron, is this something I could replace or am I better off buying a new microwave? I know the microwave is on a shared circuit, might this have caused the failure? it is only two years old. Thanks!
  • 2 more comments
  • microken Jun 11, 2008
    Thanks for the reply.
    There is a slightly louder hum, otherwise it seems to operate "normally" for about 5 seconds then simply stops and displays "F9" .
    Also, the shared circuit it utilizes has never caused it to blow a fuse.
    model # is 721.64684300
    Thanks!
  • kdmw Jul 03, 2008
    F9 error on kenmore elite ultra wave microwave. model # 721.80863400
    Sears repair says it will cost $400 to fix. he said it is the invertor that is bad.I hear the ticking noise you described. I dont trust him because I had to show him your web site before he even knew what an f9 code was!
    Please tell me where I can get the part and how to fix myself. I just know I will pay them for the invertor and then have to fix the magnatron anyway!
  • jkmm Dec 15, 2008
    I have the same error F9 today. Where you able to find the PART# and how to replace it?
  • Richard
    Richard May 11, 2010
    On some models, F9 may indicate a failed door switch. Is it making a louder than normal humming or grunting sound when operating?
  • 413 Answers
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Posted on Jun 12, 2008
I have a Kenmore Microwave Oven.The turn table stopped rotating and the unit does not heat. It sounds like it is working but it does not heat. Does the turntable have something to do with this?
What you probably hear is the fan. If it's not heating the problem is almost certainly the magnetron. The magnetron is the main component in every microwave and can be very expensive tp replace. You'll be better off buying a new microwave. The prices on new ones have dropped dramatically, I saw a 700 watt unit selling for $50.00.
Nov 20, 2010 | Kenmore Microwave Ovens
I have a Kenmore Elite Mod 721.63683300. At first I would occasionally get an F9 error once every 5 or 6 times I would use it. Now, I no longer get an F9 error, but power is reduced to about 50% as...
No, the magnetron gets its power from the inverter assembly. The actual issue here is a defective or damaged inverter. Replacing the inverter assembly will correct this issue.
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore elite mircowave model 721,62369201...has a F9 error. ?? The unit runs, but does not heat up.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 19, 2009 | Kenmore 63792 Microwave Oven
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Sears Kenmore Elite Microwave F-9 Error
My guess is that it is the main transformer that has developed a fault. If the insulation has broken down - it will arc there instead of the magnatron. Or it could be the magnatron itself. Both are prime suspects - and expensive to replace.
Unless you are particularly attatched to this - I would buy a new unit - and sell the turntable plate to recoup your losses.
Feb 04, 2009 | Microwave Ovens
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Kenmore 64683 Microwave Oven
KENMORE ELITE MODEL# 721.6368330
In every brand I can find, F9 means there is an issue with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number 721.6368330 here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 20, 2008 | Kenmore 63792 Microwave Oven
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
4,559 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
