Question about Dell (F3515), (128 MB) Graphic Card
Monitor displays vertical lines
The image is often degraded by vertical wavering lines. I can sometimes get past this problem by re-booting several times. Also when i reduced acceleration it improved.
  • Gordon  Knowlton
    Gordon Knowlton May 11, 2010
    You really should say what kind of graphics card that you have.
    What you need to do is uninstall your drivers, restart your computer and then update your drivers, restart your computer and then see if you have vertical lines. Try to turn agp fast writes off if its an agp card.
    Genius:
  • 2,028 Answers
Vertical lines can also be caused by an inverter going out, if the driver updates are not successful you might give it a little time to see if the problem area goes out completely, if its an inverter on the fritz it won't take long to go. Then you will know exactly where the problem is.
Posted on Jun 11, 2008
  • 49 Answers
Just an update. If that doesnt work then your vid card is damaged and you need a new one. Considering it is 128 mb it cant be too new. Also make sure if your motherboard is agp you get and agp card and if its pci-e get a pcie card.
I have thin vertical lines
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Samsung 50 in. Plasma TV
No image, Just red and blue vertical line on display.
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Vertical lines display
LCD Screen needs to be replaced more than likely. You can take the lcd screen apart and reseat the lcd cable by pulling it out and putting it back. You can also remove the cables from the Lcd Inverter then put them back. Sometimes it was just that they needed reseating.
You could plug an external monitor into your laptop's vga port and boot up an see if the image is clear on the external monitor. If so that means the video card is ok, but the monitor has issues.
Mar 26, 2012 | HP Pavilion dv6000z Notebook
There are two vertical lines on my monitor one is red and other is green
You may have several issues, lets try to narrow down whats wrong. When you see the lines hit the print screen button. Then go into Paint and select paste, this should make an image of whatever was on the screen when you hit print screen. Are the lines still there in the same spot? If so check the cables between your monitor and the PC. If not it is your monitor, check around for magnetic devices near the monitor if you can not find any the monitor may be bad.
Mar 12, 2011 | Computers & Internet
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
174 people viewed this question
Alun Cox
