Question about Sanyo Katana SCP-6600 Cellular Phone
Phone receiver volume
Incoming calls sound fuzzy through receiver, but voicemail replays sound fine. I rest to factory defaults, no change. The receiver volume is set at highest setting(8). The phone did not get wet. I also removed the battery and replaced it, because that's all Qwest Repair could suggest.
Any suggestions?
  • 96 Answers
The phone spearker /microphone might be damaged. Maybe if you put the volume down a little on the receiver will make the fuzz go away.
Artgirl
Posted on Jul 17, 2008
The phone does not ring for incoming calls, nothing indicates that I have an incoming call. However, if I check missed call and voicemail I can retrieve the call. Please Help
Go to phone settings then sounds and make sure your ringer volume is up and that you don't have a ringtone of Silent or off
Oct 07, 2016 | Cell Phones
Can't receive texts with certain numbers
go to contacts in the phone, go to your entry, press sub menu button, uncheck incoming calls (send calls directly to voicemail)
Jul 08, 2012 | Lg800g With 1200 Minutes And TripMinutes...
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
My incoming calls go straight to voicemail and phone doesn't ring at all. How do I change this? Thanks
Friend,
goto Tools
then call
then Call divert and cancel all call diverts
then back to main menu
then to profile
then to general
then to personalise
then select a sound THAT IS LOADED ON THE PHONE- THEY MAY HAVE BEEN ACCIDENTLY DELETED
then select a reasonable volume
then save all and have someone call you
PJH1
Jun 06, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Jan 30, 2009 | HTC PPC-6800 Smartphone
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
Can't hear people on phone
During a call, press the arrow up^ button to increase the earpiece volume. To completely reset your phone to factory defaults, press f 6 5 f. I hope this solves your dilema.
Jul 30, 2007 | Audiovox CDM9000
Sanyo Katana SCP-6600 Cellular Phone Logo
57 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
