Question about Dell Dimension 4700 PC Desktop
Optical drive not playing
Dimentions 4700 both drives are not recognising or playing media, drivers have been checked, device manager recognises hardware and evaluations say drives are functioning. They spin and flash lights, but it says "please put disc into drive" ??? how do you fix that?
  • 1 more comment
  • flyingcamera Jun 10, 2008
    cd-dvd player and dvd-rw both quit at the same time
  • Tim Babcock
    Tim Babcock May 11, 2010
    If you know how to get into the BIOS of your computer when you turn it on, check the settings in there and make sure that it is detecting them.
    If it isn't it could be a couple of different things.
  • Tim Babcock
    Is it a CD, DVD, CR-R, or DVD-R, DVD+R?
This may not apply but it's worth a shot....
Click Start > Run
Type Regedit in the run box.
Open "HKEY LOCAL MACHINE > SYSTEM > CURRENT CONTROL SET > CONTROL > CLASS >
{4D36E965-E325-11CE-BFC1-08002BE10318}
Look for keys called "Upper Filters" and "Lower Filters" and delete any values inside those keys, then restart the machine.
Note: If using Vista, be sure to right-click Regedit in the program list and choose "Run as Administrator", otherwise it won't let you change the values of the key.
Hope this helps,
Techneck09
Posted on Jun 04, 2009
Windows Media Player has stopped playing/burning?
try to read first Windows Help and support.
search for Burn a CD or DVD in Windows Media Player
or look link Microsoft Community Microsoft Windows
Dec 19, 2014 | Microsoft Windows Media Player
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cd not recognised even though device manager says drive is working well Help please?
It seems that you have no problem with software side. Then obviously the problem is in the hardware side of your DVD drive and need technician service.
Thanks
Sep 22, 2014 | Computers & Internet
No cd rom recognising in hp dv9700
In device manager, delete something like a USB device and perform a hardware scan with the menu item and it will detect the optical drive if its running ok. Then you can upgrade the driver for motherboard or the cdrom if exists on their web site. If the issue persists, check BIOS and see whether it is disabled in any way before you try to disassemble it and tighten the cable connections or try that cdrom on other machines.
Sep 12, 2012 | HP Pavilion dv9700t Notebook PC
KINGSTON FLASH DRIVE NOT RECOGNISED BY MY MAC
Try troubleshooting option for the drive and see the drivers.
If it says that ur device either doesn't have or doesn't require drivers then ur device is dead and get it replaced.
I think, only this is ur problem.
Apr 04, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My dvd writer no reading or writing
hi there,
Does the light flash on the front when a disc is inserted or have you recently installed it as a Primary/Secondary optical drive? Plus, just as a matter of interest it will only read DVD's & read/write CD's.
Your problem could be down to a number of causes including a corrupt driver, where you will have to uninstall the driver by going into Device Manager, clicking the + sign in front of 'DVD/CD ROM drives,' right clicking on the Optical Drive in question, clicking properties/Driver Tab/Uninstall (Advanced).
This will remove a corrupt driver & when you restart your system the Hardware Manager will recognise the said Combo Drive & reinstall the driver.
If it is only unable to read DVD''s then you may require the necessary Codecs for your preferred Media Player, to support various file formats. I wish you the best of luck.
Kindest regards
Ste
Apr 02, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Can't get the Cd/Dvd drive to work, Windows vista doesn't show it in the device manager, I have a n HP Pavillion dv6500 notebook around 3 yrs old
If the device manager does not recognise the drive then it has most likely failed. You should be able to remove the drive, one screw on the underside, and reboot, Once you have done this power down, reseat the drive and power up again. If the Plug and Play software doe snot recognise it then you need a new drive.
Mar 09, 2010 | HP Pavilion dv6605us Notebook
The cd drive dosent work, lights dont come on and whem i click on my computer, it dosent recognise any cd drive on the laptop. the device manager says it's a device problem.
The optical drive sounds as if it's no longer functioning. The first thing to try is change the CD drive, which in a laptop will be rather expensive. One way to circumvent the problem temporarily is to get an external optical drive.
Mar 18, 2009 | HP Compaq Presario C762NR Notebook
Cd-rom not working
IN DEVICE MANAGER UNINSTALL YOUR OPTICAL DRIVE DRIVER.GO TO MANUFACTURER SITE AND DOWNLOAD THE LATEST DRIVER.
OR YOU MAY GO TO DRIVE'S PROPERTIES AND DRIVERS AND CLICK ROLL BACK DRIVER.PROBLEM SOLVED.
Nov 24, 2008 | Computers & Internet
Aspire 4520 DVD combo problem
try uninstalling the drive in device manager then reinstalling it allso check for bad connections
Oct 14, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dell Dimension 4700 PC Desktop Logo
80 people viewed this question
Alun Cox
