SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
SOURCE: sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
SOURCE: sony wega KV-36FS13 standby light blinking 5
Ur power ic inverter board is dead.
U need a new one.
SOURCE: TV wont turn on, sandby light flashes 7 times.
Any malfunction associated with a flashing stand-by light usually indicates a
circuit problem or defective component. Unfortunately, the days of
taking off the back cover of your TV and replacing a defective tube or
fuse are long gone. Proper servicing will require troubleshooting
procedures that can only be performed by a qualified electronic repair
facility or professional television repair person. Ask for an estimate
and a realistic appraisal of whether the set can be adequately fixed.
Depending on the age and condition of your TV it may not be cost
effective to repair.
