Question about E-Machines eMachines Desktop PC
Troubleshooting HDD wipe and Installing new Windows
Hello.
I am having some trouble with my eMachines desktop computer. The madel is a T4510. The original power supply burnt out so I replaced it and it works fine, but from before, the HDD had some bugs or viruses in it and so I wanted to completely wipe the drive and start over new with a clean install of Windows XP Pro. I have the disk and I ran through the install, and when it reboots itself it automatically goes straight back through the Widows install. It seems like it doesnt recognize that I just installed it. What am I doing wrong?
  • 8 more comments
  • jigglinbiggi Jun 11, 2008
    But the weird thing is, is that I did delete the partitions...
    Through the Windows XP install disc. It lets you delete any previous partitions and i did that so I could start over brand new.
    Well I tried to reset the Bios to where it starts from the hard drive after it boots, but i believe it still does the same thing. It acts like i didn't just install windows and so it wants to go back through the setup process.
    I've tried that and it tells me that I need to insert the boot cd.
    It does the same thing it did before. install --> reboot --> install...
    No the cd is in perfect condition. It just sucks now that I have to pay some guy to do something I probably could've done myself, but jsut never thought of it.
    It uses an 100gb IDE drive.
  • brian c
    brian c May 11, 2010
    Jigglin, does this PC use a SATA drive, or an IDE drive with the ribbon cable??
  • brian c
    Does this thing use a SATA hard drive, or an IDE drive?
  • brian c
    Sounds like you didn't delete all of the partitions before you formatted.
  • 106 Answers
I think you might have either bad memory or a bad hard drive caused by the bad power supply.
Reseat the memory into a different slot and instead of performing a quick format, select the second option (the long one)
Make sure your bios is not set to only boot from CD. after the first install, I'd access the bios and change boot order to hdd then cdrom (so that you don't get tempted to hit the ANY key when the cd loads) :)
Posted on Jun 15, 2008
  • 2,794 Answers
How did you wipe the hard drive?
Posted on Jun 10, 2008
  • 3 more comments
  • Tim Babcock
    Tim Babcock Jun 11, 2008
    Did you use a 3rd party program to wipe the Hard Drive out with?
    There are few out there that once you wipe it out, it can make your drive unusable.
  • Tim Babcock
    When it reboots is it rebooting off the hard drive or the CD.
    If it's going back to CD after install you will be caught in a loop.
  • Tim Babcock
    When it reboots, take the CD out and see what happens.
  • Tim Babcock
    Go ahead and put the CD in now and see what happens
  • Tim Babcock
    I would have a technician look at it and see if there is a step missing here or if there is a hardware failure going on.
    The Windows CD isn't scratched up is it?
Looking for the front panel wiring diagram for a emachine T4510. The Power LED & the Power SW are disconnected! HDD LED was never unplugged! I need to know where they need to be!
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
Jan 30, 2011 | E-Machines eMachines Desktop PC
Computer won't boot - fan on cpu does not run - cd drive does not power up -
Hi.
If there is no sign of life, then it is usually a power supply problem. Check PSU connector. If PSU fan does not turn on check the power cable. If power cable is good, test power from PSU using a multimeter and eventually replace PSU.
Dec 03, 2010 | E-Machines eMachines Refurbished EMA...
I replaced installed additional RAM in my eMachine T4510 but it wouldn't complete POST. Removed the new RAM and re-installed the factory-original RAM and it still wouldn't complete POST. Removed all RAM...
In your motherboard there will be a CMOS battery remove that battery and put it again you will get the display in your monitor, the battery will be in coin size the battery is CR2032.
Oct 18, 2009 | E-Machines eMachines Refurbished EMA...
T4510 wont read CD
is your computer toshiba ?
if yes try to setup booting option before you run windows , some computer ask to press f10 or f1 or f3 . so you have to see what computer say .
Jul 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
System/config is missing or corupt
Go to your start menu and click run, type msconfig... Please give me a good vote. It means a lot to me and if you have more questions please feel free to ask me.
Jul 04, 2009 | E-Machines eMachines Refurbished EMA...
NTLDR is missing. Press ctl+alt+del to restart.
I assume you are using Windows XP. This is what you do:
Windows XP users
  1. Get a Windows Installation CD. It doesn't have to be yours, anyone will do.
  2. Insert the Windows XP CD into the computer.
  3. When prompted to press any key to boot from the CD, press any key.
  4. Once in the Windows XP setup menu press the "R" key to lauch the Recovery Console to repair Windows.
  5. Log into your Windows installation by pressing the "1" key and pressing enter.
  6. You will then be prompted for your administrator password, enter that password. If you have none set, just press Enter without typing anything.
  7. Copy the below two files to the C:\ directory of the primary hard disk. In the below example, the files from the CD-ROM drive (which in this case is "D:\" are copied to the C:\ drive. This letter may be different on your computer.
    copy D:\i386\ntldr C:\ (hit Enter)
    copy D:\i386\ntdetect.com C:\ (hit Enter)
  8. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | E-Machines eMachines Refurbished EMA...
Keeps restarting
if you have another pc with updated antivirus
troubleshooting:
try to take your harddiskdrive to the other pc and set it as 'slave'{you can see how to set it at the front of HDD}
then start windows;scan your HDD by antivirus,and delete the detected virus!
antivirus: kaspersky or avira will do.
hope it will help you. tnx 4 using fixya!
Oct 15, 2008 | E-Machines eMachines Desktop PC
Ethernet drivers
Most drivers can be found at Drivers.com.
Jun 17, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Emachines doesn't start
Hi!
Is the power supply the same rating?
Is the HDD spooling up?
Do you hear the post beep?
let me know soon, Thanks
May 22, 2008 | E-Machines eMachines Desktop PC
T4010 100Gb HD
try to fixed HDD inside the system some wiring maybe lessen.
If not solve, change the cable connecting the HDD.
if not solve; Try boot the system with windows installation disk.
if still see the problems.
HDD maybe damage
If the the disk is detected;
You should back up your files and install new windows if it is necessary.
Jan 02, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
64 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
