Question about Fujitsu 24C1 Air Conditioner
Mold in Fujitsu 18 c1
There is mold and dust inside the entire unit and especially at the swing/fan. Does anyone knows how to clean it without taking the entire indoor unit of the wall? Are there any detergents I can spray inside?
  • Anonymous Jul 22, 2008
    I noticed a foul smell and there is mold where the air comes out and dust everywhere. Aside from cleaning the dust and mold off the visable parts, what else can I do? Where is the mold coming from?
SOURCE: The bin stinks like mold
Have had machine for 6 years.  Mold is an issue.  Occatioinally I clean out the drawer and behind the grey rubber seal with vinegar.  After a load is washed, I dry off seal and leave door slightly open.  Occationally I also wash a load of nothing but bleach.   Hope this helps.
Posted on Dec 30, 2007
gittos73
  • 244 Answers
SOURCE: Mold in Washer Dispenser Drawer
no its not what it is is the dispenser never gets air to it to dry it out what you need to do is pulcompletely out some need yanking out and some need to be pulled open and then push down at the back and pull that bit more once out u will need to put it in the sink wash the inside and th bottom of it now u will need to clean the inside of the washer were the dispenser goes the mouldwill be bad in there once done u can replace the dispenser now to stop this from happening once the washer has finished its cycle slightly open the soap drawer to let air get inside this will dry it out naturally and wont build the mould up again shown this to alot of my customers and it doesnt happen again let me know how it goes
Posted on Jan 24, 2008
SOURCE: NEED SERVICE MANUAL FOR FUJITSU SPLIT SYSTEM
try, http://www.uelements.com/downloads/Fj-aby14rga-sm.pdf
Posted on Jan 07, 2009
  • 400 Answers
SOURCE: Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Posted on Apr 15, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
How to remove mold in unit
bleach in 1/3 dilution with water
exit mould type off the shelf products
could try vinegar and water
Oct 26, 2016 | Washing Machines
Black mold inside unit, fan becoming noisy, I have a hunch that it,too, is covered with black mold.
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Aug 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
The styrofoam inside the unit is covered in black mold. I was wondering what i should do if anything.
Any mold in any part of the unit is not good, especially if its in the Styrofoam, Styrofoam has pores and hides the mold spores well, it would be dangerous to actually run the unit with mold spores as it can travel inside the house. Unfortunately companies that make these units don't make these units mold proof, why should they? that's how they make their money. I have three units, one has always given me problems with mold. It always comes back. The other two are always clean. My best advice, get rid of the unit and get another one or get a free estimate on Central air and heat. Mold is very dangerous and is not worth the risk, it can cause a number of medical issues.
Aug 16, 2011 | Haier HWR08XC7 Air Conditioner
Fan WORKS FINE but has lots of dust and mold inside that needs to be removed,and I've taken the screws out, all except the one near the base, located right above the LABEL. This screw, a Philips head,...
there had to be reason the Fan was not to be disassembled .... yes you will need to buy a new unit... MOLD as you is bad thing. If you're allergic to Mold. you be hard pressed to disinfect the whole unit. for sure you will miss some of the Mold. It will come back.. The Mold is due to too much moisture/ Humidity. on top of getting new Fan unit you will need to get Dehumidifier, to remove the moisture in the room...
If dust collects in the new fan. at least you will able to clean out the dust.... if some of the screws look like a star and not a phillips, you can find 1 at hardware store. take a picture of it with your phone. show it the hardware girl or guy. they will be able show what you need to Disassembling the Fan. good luck shopping list
1. Dehumidifier
2. new fan
3. take a picture of not normal screw, when you need to disassembling fan gain.
Mar 12, 2017 | Aloha Housewares Breeze 29" Tower Fan
After taking my AC out of storage for the year I just discovered Black Mold growing inside the unit . Is there a way to take off that air flow screen and get in there to clean it out? What would be a...
remove the screen to get to it but follow these precautions.
In order to get mold out of various surfaces, it is important to first obtain proper protective gear. You should check to make sure you have all the necessary protection before you start, such as goggles and a disposable outfit which you can wear during the cleaning.
The first step is to wet the moldy area with water and soap spray. This stops the mold from continuing to spread through the air, which it will do if you do not spray it first. Then, you can use a vacuum to **** away remaining mold spores from the affected area and any surfaces close by which might also be affected by mold spores.
Next, you want to be sure to rinse all areas where you have scrubbed. You can use a wet-dry vac if necessary if too much water has collected. You should then take some bleach and water and apply it to the surface where containing the black mold. Warning: do not mix bleach and ammonia! This can lead to a deadly combination of gases. Make sure you follow the instructions on your cleaning ingredients labels.
You will probably have to leave the solution on the affected area for 6-8 hours or thereabouts. It should be able to dry on its own. You can also use fans, dehumidifiers, and any other type of air circulation device to let the area dry as quickly as possible.
It is important to note, however, that it is very important to let the mold dry; otherwise, it will reproduce. Every mold spore must have a chance to be completely wiped out to prevent it from coming back at any further date. Once the entire contaminated area has been scrubbed away, it should be okay to start using the previously affected room again for any usual purposes.
Ultimately, black mold removal must be done with care and caution. You must ensure that every surface which has been affected is thoroughly cleaned. If it is not, you run the risk of mold returning which can cause serious health problems, as mold is a deadly substance and can create huge issues for any house or building which is affected by it.
Be sure to properly protect yourself when cleaning non-porous materials or any other household surfaces while you remove mold, both to prevent damage from the mold itself and from the chemicals you use to clean it away. This is very important to ensure good safety and preventative measures for mold removal and permanent care and treatment of the moldy spots.
Jun 08, 2011 | Sovereign ARP-900E Air Conditioner
Can mold accumulate inside rooftop dometic air conditioner? How to clean rooftop unit
Mold could easily form inside.I am not familiar with the unit but if you call the/a dealer,they will usually tell you how to take the cover off free.If it is just clipped on they would know the best way for removal also.All I would do is start removing visible screws which appear to be holding on the cover.Clean the mold off with bleach/water mixture using very little bleach,clorox spray or something similar.Good luck! Greg
Aug 31, 2010 | Dometic Rooftop RV Air Conditioner
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Mold inside unit
There is a product on the market that will prevent mold from growing in your air conditioner.You should be able to find it at a refrigeration supply house.Just take the product and place it in the area where the water collects.There is also a product to help you clean your unit of contaminants on the heat exchanger surfaces.It simply sprays on,and can be later rinsed off.Its usually a straight forward matter to remove the cover from an air conditioner.Usually no more than 4 screws.Some units will slide out of their covers,after removing the screws that keep them locked in place,and some covers simply lift off from the rest of the unit once the screws are removed.In either case the rest of the unit minus the cover will remain intact,and can be cleaned.Cleaning the unit will almost always make it work better too,so your killing two birds with one stone.
Jun 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
Jul 12, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Fujitsu 24C1 Air Conditioner Logo
159 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
