Question about Mitsubishi VS-50605 50" Rear Projection Television
VERTCAL HOLD MY MITSUBISHI VS-50605 TV HAS SEVERAL LINES RUNNING ACROSS THE SCREEN . IT USUALLY TAKES ABOUT 15 TO 20 MINUTES TO CLEAR UP . (AFTER I TURN IT ON ) THANKS FOR ANY INFO YOU CAN GIVE ME . JERRY PIERCE jerrypierce123@bellsouth.net
Big irish sounds good but without any wiring schmactic or diagram all that means nothing to us..
Posted on Sep 23, 2008
  • 927 Answers
Good Day, marvy21; try theses ideas, they will fix the TV # 3 is most common, you might start there. 1). VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. 3). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Posted on Aug 30, 2008
Vertical hold problem on mitsubishi rear projection VS 50605 can't find reset button. Where can I find it.
Your Vertcal Hold Problem Is Due To Lack O f( Sync) Hold Which Is Usually Caused By Defective Filtering In The Vertical Output Circuit
Sep 10, 2014 | Mitsubishi WD Televison & Video
My tv has horizontal lines till it warms up,only a couple minutes then it is pretty much clear.it is a 42 inch projection tv.Is it the bulb?
This is a sign that you should be looking for a new TV. Tubes are getting old along with components and it takes more High Voltage when first powering it up that cause these retrace lines.
Feb 02, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
How to take off protection screen of a Mitsubishi VS-50605 50 in. Rear Projection
Usually have to pull the speaker grill off (friction fit), there will be some screws under the bottom edge of the screen, if there are wires you may have to unhook them, sometimes the plugs are behind a pannel that gets unscrewed from the front. The frame will come apart to drop the new screens in.
Jul 14, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Lines through picture
this unit needs new convergence ics.It should run about 250 for repair from a honest tv repair shop.
Mar 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
