Samsung Airconditioner AW109AB
I have a problem with this Samsung A/C unit. It builds up frost on the finns behind the air filter. It covers the finns completely and the a/c does not cool as good. What do I do?
    Scholar:
  • 104 Answers
First is to make sure that your air filter is clean so you can move adequate air. If it is already clean, then you have a freon leak. The unit could be repaired by an a/c tech but repairs are almost always more costly than purchasing a new unit (I assume this is a window unit)
Posted on Jun 12, 2008
When the heat pump is running in the fall, I notice frost build up the next morning. What cold cause this problem?
Heat Pumps and Refrigerators are the same unit running backwards. To get refrigeration you create heat, to get heat, you create frost. The end blower is the thing that either gives you heat or cold air depending on what setting you are choosing.
To stop the frost building up, you just need to cover that area with insulation. The frost is caused by a cold surface that is below freezing point and water vapour in the ambient air.
Nov 19, 2016 | Frost Refrigerators
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
We have a Carrier 25HBA unit and we've noticed a frost build up on the outside compressor, my husband turned the unit off and cleaned everything outside and up in the attic. It worked. No frost...
Hello
Frost or ice on the bigger outside copper line is a indicatin of possible low freon.Hopfully that is all it is.
It is also a possibility the compressor is getting ready to break,bad valves.
You will need a tech to come out and charge the system with freon.
Check your filter is clean and new first.
Sep 15, 2011 | Heating & Cooling
On my zoneline when you have the a/c on there is a ice build up going across the front of the unit just behind the filder you have to turn off the unit an let the ice melt off
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2011 | GE Zoneline AZ25E12D3B Air Conditioner
FRT221RSH refrigerator warm...freezer cold...some frost on back of freezer wall, i popped off the small cover on the inside back wall of the freezer and the fan there is running...i vacuumed a little dust...
If you remove the entire back panel of the freezer section there is a evaporator (aluminum grill looks like a car radiator, contains r-134a, do not puncture or unit is ruined) Some frost on back freezer wall, means probably this entire grill is encased in frost, not allowing any air flow, which is how the entire refrigerator section is cooled, by air flow) The frost build up has to be removed,(got a hair dryer) you can unplug it for a couple of hours with the door open, overnight is better,this would fix the problem for a couple of weeks....Your automatic defrost is not working, there are three parts- the timer or control board, a heating element, and a bi-metal thermostat(often the problem)
You popped off the cover for the ice maker, you need to defrost the whole freezer section behind the back panel. Freezer cold means your compressor and freon are fine, you have a defrost problem with ice build up restricting air flow. A normal automatic defrost runs every 8 hours, three times a day, rule of thumb.....Sounds like you have a couple of weeks built up...........
hope this helps
Feb 23, 2011 | Refrigerators
Portable airconditioner keeps shutting down and is very hot behind the unit
Make sure that there is good air flow. Find the filter and make sure that it is clean.
Feb 06, 2011 | Heating & Cooling
Water is dripping from the front of the unit.
have the unit charge checked it could be low if not low then the coils might be restricted either by dirt or finns dammaged or check for any kind of air flow restriction
Jan 03, 2010 | Fujitsu 24C1 Air Conditioner
Air filter for frigidaire electrolux airconditioner where does it install?
On most window units, the return air filter goes behind the cover panel, on central air units they go in the return air side of the air stream
Aug 02, 2009 | Heating & Cooling
Airconditioner has weak cooling power.
if all the coils on the out side and inside units are clean and the fan motors are running fine it sounds like it could be low on freon
Dec 11, 2008 | Heating & Cooling
Ice or frost on the inside coils of the ac unit
Reduced or no airflow, Evaporator may be dirty. Low on freon.
Jul 31, 2007 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
