Cd rom driver won't open,
How do I open my CD rom driver
  • Anonymous Jun 30, 2008
    in what program or window can i click to have my hp note book open by the computor's command ?
  • 58 Answers
There is a pin hole, just below the cd-rom tray where you can use a paper clip to push inside. That will open it.
Posted on Jun 10, 2008
  • jlopez327 Jan 30, 2011
    Very helpful. I recently recovered my pc and I needed to install software back onto the pc w/ CDs. Well the CD rom was stuck so I was able to get it open using a pin and pushing into the pinhole. after a few tries it manually opened. Thanks
I alraedy did it. please tell how can open this
Posted on Oct 07, 2008
4 Suggested Answers
  • 15 Answers
SOURCE: I need to download a driver for matshita cd-rom cr-176
The driver you are looking for might be found here, http://www.cdrom-drivers.com/drivers/0/104.htm
Posted on Dec 31, 2007
SOURCE: repair my cd rom driver
What is your Operating system? As far as I know, the computer will install it automatically?
Posted on Feb 20, 2008
  • 998 Answers
SOURCE: CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Posted on Oct 17, 2008
DVD FUNCTION WON'T WORK, what should i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 11, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Won't play a dvd
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Oct 07, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
I own eMachine Notebook e525 and it won't read any disks. I have tried multiple disks such as music cds, installation cds and video dvds. None of them read or open. There isn't even an icon for the...
> there is no icon for the CD-drive
Probably means that either:
* no electrical power is reaching the CD-ROM drive
* no "data" is being transferred to/from the drive
* the electronics inside the CD-ROM drive have "died"
Check the "power" and "data" connectors.
If necessary, replace the drive with a new CD/DVD reader/writer.
Jun 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
The DVD drive in my new Aspire 7741z-4433 won't read any discs - CD or DVD
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 04, 2011 | Acer (KV.16X04.007) DVD Drive
My cd rom drive will not open ive tried the paper clip method and still wont open anything i can do please help
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
if you mean a driver for cd/dvd driver
if your computer came with a disk all the drivers should be on it (motherboard disc)
hope this helps
Jan 06, 2011 | Compaq (120192-B21) CD-ROM Drive
Installed asus combo CB-5126A but my computer won't recognise it. If a CD is placed in it won;t work on the computer I can just hear the cd whirring.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 11, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Cd drive wont open
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
774 people viewed this question
David Payne
David Payne
