Question about Lands Phones
PANASONIC KX -7030
The FWD/DND button is lighting and we don´t know how to do for desactiving this.
Thanks!
  • Anonymous Dec 10, 2008
    panasonic kx-t7030 not working
5 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Posted on Nov 16, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7030 FWD/DND button
Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
Carl
Posted on Jun 23, 2009
cnavarro
  • 2460 Answers
SOURCE: I have a Panasonic KX-T7030 Hybird system and
I think you can press FWD and dial 0 to reset. If that doesn't work, try dialing 700+ your extension on the intercom. That should always work, no matter what system the phone is connected to.
Of course, if neither one works, please post back the model number of your SYSTEM cabinet (the white box in a closet, electrical room, back office, etc.).
Carl
Posted on May 26, 2010
cnavarro
  • 2460 Answers
SOURCE: Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Posted on Nov 03, 2010
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7030 corded phone has lost its
Somewhere in your user's manual you will have code instructiohns for CALL FORWARD. It starts with 71. In a TA series it's 711+ext+#. In a TD 710x+ext+#. The conditions vary, and the TA has very limited forwarding codes 1/2/3
In a TA you can also press the FWD button and dial 1+ext+#.Your other choice is 2.
Both of those are done while listening to intercom dial tone.
Carl
Posted on Nov 17, 2010
FWD/DND will not turn off by pushing what can I do??
Try pressing the DND button and pressing the zero touch tone button, see if that turns the light off
Jun 11, 2015 | Panasonic KX-T7453 Corded Phone
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Carl
Nov 03, 2010 | Panasonic KX-T7730 Corded Phone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
Take the phone off do not disturb
Try pressing the FWD/DND button and look at the display. It might have 3 steps, FWD, DND, and FWD/DND Off. When you reach the Off part, the light will go away.
Carl
Sep 23, 2010 | Panasonic KX-T7630 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Lands Phones Logo
399 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
