Question about Connex 3300 240-Channels Base CB Radio
Adjusting the vr pots
Hi.
I got a Connex 3300 (not hp ) from a yard sale and it is out of adjustment.
I have a Dosey TC3001 P meter.
How can or would I go about settings the VR pots back to stock settings?
Can it be done with my meter?Thanks
GOD BLESS
    Scholar:
  • 66 Answers
A word of advice, never buy a radio second hand. Used radios are sold for some odd reason, and it may be because it is broken. And yes you can do it with your meter, you just have to tune the radio using Coarse and Fine adjustments, also use peaking if you know how, to get a better transmit and receive.
Posted on Jul 02, 2008
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Apr 20, 2015 | Connex Radio Communications
Cb radio modulation
www.cbtricks.com
use the vr adjustment points to adjust the AMC modulation. DO NOT cut the mic audio limiter tr-32 or the modulation limiter tr-54. it will over-modulate and splatter out of band if you do
Feb 15, 2014 | Connex 3300, Deluxe Amateur Transceiver,...
I have a connex cx3300hp i need to know the vr adjustments for meters and power and i dont have no modulation please help me jerry.? thank you.
i have a 10k on a quad mag mount my radio is a galaxy 98vhp peaked and tuned and i talk every where i key on base stations no problem that antenna is a beast you have some issues goin on over there u need to get that tuned i have a flat 1.0 and i run around 250 true watts and my swr never goes past 1.1 you wanna be loud n talk tune that puppy right biggest thing for them is ground best thing is to run it on a huge magnet best ground there is and you have to have good coax that has alot to do with it just tiny little things you have to check make sure everything is set up correctly
Oct 25, 2013 | Connex 3300 240-Channels Base CB Radio
Would like to peck recive on connex 3300 moble
adjusting the receive is something you don't want to touch unless you know a radio.....and for the rci2990 without looking at it I'd say you have a bad soilder on the voltage regulaor or the voltage reg, died.
Jan 15, 2010 | Connex 3300 240-Channels Base CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Jul 15, 2009 | Connex 3300 240-Channels Base CB Radio
No audio meter needle swings on another radio
is the radio working? sometimes the meter just dies that will not effect yor radio
May 30, 2009 | Connex 3300 240-Channels Base CB Radio
Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Owners manual
You can get the ownwers from a website called cb tricks
Jul 10, 2007 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
564 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
