Question about Beverage-Air Beverage Air KR48-IAS 44.9 Bottom Mount Refrigerator
Refrigerator Keeps running
I've got a beverage-air worktop refrigerator (model WTR 48A) that seems to run full blast constantly. Even when I turn the thermostat to off it keeps on running? Can this be fixed by simply replacing the thermostat or is there more to it?
  • 122 Answers
The thermostat sounds bad. It should turn off the compressor when turned all the way to the left. On some units the fan by compressor will stay on when compressor is off. Keep that in mind. If your thermostat is stuck closed the unit should be running too cold. I can hook you up with a thermostat. :) www.northeastcooling.com
Posted on Sep 23, 2009
    Scholar:
  • 81 Answers
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Posted on May 02, 2009
  • Sounds like your thermostat is stuck or bypassed. I would start with replacing the thermostat. The part # is 502-302b. You can order from your local repair service.
4 Suggested Answers
farfield
  • 462 Answers
SOURCE: fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Posted on Apr 01, 2009
  • 856 Answers
SOURCE: beverage air dd58 kegerator won't stay cold
the freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
Posted on Jul 11, 2010
  • 856 Answers
SOURCE: I have a beverage air kegerator that seems to work
as a general rule,coolers have the fans run 24/7. Freezers will have the fans shut off during the defrost cycle. If unit maintain temp., I'd not be concerned by it.
Posted on Oct 10, 2010
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
Is it normal for the fan to run all of the time? Even when the compressor is off.
Good day,
If it is a beverage cooler, then yes, that is normal. It allows the temp to remain constant from top to bottom. Domestic refrigerators as a rule shut the fan off with the compressor, but on most any commercial cooler regardless of it's application keeps the fans running all the time.
Aug 27, 2010 | Carrier Beverage Air® Marketeer® MT12-1-B...
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Beverage-Air Beverage Air KR48-IAS 44.9 Bottom Mount Refrigerator Logo
286 people viewed this question
Top Beverage-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
