Question about Brother HL-6050DN Laser Printer
Toner end of life
i am having problems resetting back above message on brother 6050dn.
many thanks
P.
    New Friend:
On the left side of the toner twist/reset the gears
Posted on Jul 08, 2013
    Problem Solver:
  • 5 Answers
Press Go and Set at exact the same time
press < one time
press Set
choose "Nothing"
press Set again
Posted on Jul 13, 2009
  • peter kuria Jul 08, 2013
    thank you but i have tried this method but i have not being helped
I changed the toner cartridge and when started back up, it goes though initiating and then says "toner life done" "replace cartridge. using brother brand. never had this problem b4.
Do you have another toner? Seems like the chip was not reset when they recycled the cartridge. Call your supplier about a replacement if another toner fixes the issue.
Jul 24, 2015 | Brother HL-6050DN Laser Printer
Toner life end message despite new toner
. To reset the "Toner Life End" message on the Brother MFC-8460N Open door press Clear/Back key
Apr 22, 2014 | Brother MFC-8460N All-In-One Printer
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
Brother HL-6050dn Toner Life End Message Tried covering the eye Tried Go-Set and changing to Nothing solution Still red message saying Toner Life End
I just got through this problem, The customer had a "refilled cartridge.
The Flag on the left side near the gearset of the Toner cartridge was not
brought back to the proper position, just undo the three srews and reset the flag.
works like a champ,. your welcome.
Dec 08, 2010 | Brother HL-6050DN Laser Printer
How to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Oct 17, 2009 | Brother MFC-9840CDW Laser Printer
Toner cartridge is full - "toner life end"
when the printer is in "ready" state, press the GO and SET at exact the same time.
Now, using the (-) < button you can choose any "service" option to fine tune te printer
TONERLIFEEND is the first in the list, press the "set" button en chose "Nothing" and press "Set" again
Jun 22, 2009 | Brother HL-6050DN Laser Printer
Toner end life message
i solved the brother mfc8860 toner life end problem
hi guys my name is reedwaan. Im new at this site so please listen up
my brother toner i refilled with toner and inserted it. It said toner life end then i patched the windows close on the sides and still the same problem, then i removed the toner and loosened the two screws on the left by the gears then removed the cover of the gears.
Right at the back there is a funny looking gear with a spring behind it. All you have to do is pull the spring a little bit clockwise and push the gear back on hooking the spring into it so that the gear is spring loaded. close it up then test it, It took me a while to figure it out but i got it right.
NB*  The gear that you push on, is the toner reset gear and when you push it on make sure the teeth dont interlock with the second gear on the left of it. If you have any queries mail me on reedwaan@yahoo.com
glad to help out
Jul 07, 2008 | Brother MFC-8860DN Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Toner End Life
Ther is a small viewport (about 1/4" dia) on each end of the cartridge that a photo sensor apparently shines through. The port is not near the bottom, so there's room for plenty of toner below it. Put a small piece of electrical tape over one of them and it will print fine..
Just a thought it worked for soe of my frnds..its worth a try..
Oct 24, 2007 | Brother HL-6050DN Laser Printer
Brother HL-6050DN Laser Printer Logo
484 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
