Question about GE DBXR463GB Gas Dryer
Installation of part no. WE4M190 (timer) in GE gas dryer DPSQ475GT5ww
I am ready to install this part, but it is not clear to me how it is fastened to the plate where it is attached. Even after I look at it, it is not totally clear how it attaches to the plate. Could you please help me with this?
Thank you
Note: I had to ask under a different model number, because I could not find my model number in your data base.I would appreciate your help.
mlpatino@sprynet.com
    Sergeant:
    Champion:
  • 324 Answers
Take off the back panel look closely at the timer you will see a tab that you carefully pull up a little and twist the timer off. to take off the knob in the timer opposite the knob there is a pin that you pull out and the knob will pop off.
Posted on Nov 19, 2008
Tip
Choosing a dryer.Gas or Electric
A gas dryer saves electricity cost, but requires an installed gas line to the home and special installation. If gas is available for a dryer, the outlay for a gas dryer model may be a good option if your dryer usage is high. An electric dryer costs less, but requires installation and energy costs for a dryer varies with usage. Both types of dryers require proper venting to the outside. Always follow the dryer manufacturer's installation recommendations.
on Aug 17, 2010 | Refrigerators
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
Ge dryer Model # DPSR473EWOWW coil proper installation
once you get the dryer apart & remove the drum its very simple
a 10 minute job if that & if your not sure get a service tech so you dont do more damage
Apr 21, 2014 | GE Profile DPSR473EW Dryer
The timer on my Maytag DG212 dryer sticks and does not advance so it just keeps running.
You will need to change out your timer, as it is non-repairable.
Hint:...Be sure to get the same brand/mfg of timer, or be somewhat of an electrician because if you do not get the same timer it will not be wired the same.
Also only remove and replace one wire at a time, it will keep you out of trouble and ease the installation of the timer.
Please rate me
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
Dryer does not shut off / timer does not advance
Unfortunately this usually means that the actual timer mechanism is bad within the machine. This is not something you can fix and will require a new mechanism which you can either have a repairman come and install or buy a new one at an appliance part shop and install yourself. Installation of a new timer is fairly simple and should only require a flat tip and phillips head screwdrivers and about 15 minutes.
Dec 12, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore gas dryer
is this in the auto mode or timed mode??
Jan 25, 2008 | Whirlpool LGV4634JQ Gas Dryer
GE DBXR463GB Gas Dryer Logo
158 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
