Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Access 2003
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file...
(More)
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file that's in the format shown below? I'm trying to import this file into an Access database table. The file has spaces between each line which is what is giving me a fit. Please look at the file layout and example below. Text File Layout: a = Lockbox #: (6) digits and (4) leading spaces. Postions 1 - 10 b = Site ID: (2) digits and (8) leading spaces. Postions 11 - 20 c = ISA #: 10 spaces. Postions 21 - 30. Not used currently d = Cust #: 5 spaces. Postions 31 - 35. Not used currently e = RG Key: 11 spaces. Postions 36 - 46. Not used currently f = Tran Code: (4) digits (4) spaces. Postions 47 - 50 g = Record #: 4 spaces. Postions 51 - 54. Not used currently h = Count #: 2 Spaces. Postions 55 - 56. Not used currently i = Volume (17) digits, zero padded to the left of volume. Postions 57-73 j = Dollars (14) digits, zero padded to the left of volume. Postions 74-87 k = Description: 240 spaces. Postions 88 - 327 l = GL #: 23 spaces. Postions 328 - 350 m = Adjustments: 3 spaces. Postions 351 - 353 Text File Example: 105243 12 4101 00000000000009552 105243 12 4102 00000000000000325 105243 12 4108 00000000000043838 105243 12 4110 00000000000043838
I am getting the message "Module not found" after deleting a form that I no longer use...
(More)
I am getting the message "Module not found" after deleting a form that I no longer use anywhere in the database. If I put the form back - issue goes away. If I rename the form - comes back. Something is calling this form but I can't see what. Nothing references it in VBA, macro, query, etc. Where can I look next to see what is calling this thing?
