Question about GE (PSS26MSRSS) Side by Side Refrigerator
Psf26rgwa The left inside of the refrig is profusely sweating. the sweat runs to bottom wher it pools, also there is big ice chunk behind the bottom drawer. This is the 2nd new GE profile I have had delivered within a couple of months and there is still problems. what do I do next
  • 1510 birch Aug 08, 2008
    Yes it was in the home 2 days and the repairman that came sid he never seen anything like it. Still working on it. Thanks
    Champion:
  • 210 Answers
Is it under warrenty?
Posted on Jul 22, 2008
I sweat profusely! Can excessive sweating damage my Resound hearing aides
No they are waterproof to a certain extent. you could email the maker?
Feb 24, 2017 | Heating & Cooling
Grill temprature not down
By grill you mean the air outlet?
If the large line going to the compressor is ice cold and the coil is not sweating profusely the compressor may have become inefficient which is not repairable.
Jul 29, 2010 | Hitachi Heating & Cooling
I have water running from under the passenger side interior floor board what could it be coming from or has any one else experienced it really flows when turning corners
It sounds like condensed water from the air conditioner. Just like a glass with ice in it sweats, the cold part of an air conditioner sweats. That water needs to go somewhere. There is a drain on the bottom of the ductwork that comes out under the car, often toward the passenger side.
If the drain gets plugged, the A/C still sweats, but the water builds up inside the ductwork.
You can often clear the drain by blowing some air up the drain from the outside. (Don't use too much pressure!)
Jun 15, 2010 | 2000 Pontiac Grand Prix
Inside sweating and turning to ice
sounds like condensation. place a film of vasoline on mating surface of gasket and make sure door is shutting good.
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sweating and condensation just above the door
If you see a switch inside the refrig about , click to " save energy " , click it to " not save energy " . This will turn a heater on behind the strip , which will keep moisture from being between the frig and freezer door .
Nov 21, 2009 | Amana Refrigerators
The inside of the refrigerator sweats profusely, especially in humid weather. The unit is 20 years old. What could cause this problem
Hi, This is usually caused from a bad door seal. Checkand make sure the door is sealing tight on all sides. Also make sure the little switch near the controls is set for humid days.
Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Refrigerators
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Old GE refrig is sweating /dripping inside
If you run a 5 inch or so piece of aluminum wire from the defrost heater into the drain hole after you defrost the freezer that should fix the problem for good!
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
KJ4QOB
Da Doc
Jim Akins
