Monitor problem my computer worked last night, I left it on when I went to bed, this morning when I went to use it my monitor wont stay on.. when I push the menu button on my front of the screen it comes up that there is no input and then it say the monitor is going asleep... and it shuts off.. I have restarted it several times, and unplugged and plugged back in both the power cords and cord that connects to the tower... please advise..
  • 1 more comment
  • Supposed2b Jun 10, 2008
    I get the same 'no input signal' message then the monitor powers off. In addition, my optical mouse and the keyboard appear to have no power being suplied to them.
    Nick
  • Anonymous Jul 06, 2008
    monitor message no input and then goes into sleep mode
  • yankeefan755 Sep 07, 2008
    monitor worked this morning. Disconnected entire system and relocated in other area of house. Got everything back on except monitor-- ANALOG SIGNAL OUT - ASLEEP. I've unplugged and restarted but nothing.
Ericalin, Thanks for your help. Tested all and the problem isolated to the tower. BB GeekSquad is sending it to cental repair for waranty service.
Posted on Jun 10, 2008
    Scholar:
  • 47 Answers
Erickalin - it sounds like your computer might have shut down and failed to come back up again. If you have access to another monitor, try hooking it up to your computer instead of the one you normally use (that won't stay on). If the second monitor won't stay on, the problem is your computer. You might have to take it to your local computer geek or computer store to get serviced. If your computer DOES work with the second monitor, you might need to have your monitor serviced or replaced. Good luck!
supposed2b, I think you have the same problem, although your computer doesn't even sound like it's powering up. Your power supply might be faulty or an internal component (CPU or memory most likely) of your computer has died. Double check your power connections and ensure that when you press the power button you hear the computer start up and the light on the front comes on (hopefully green or blue, but not yellow or red). Again, you might need to take your computer in for service.
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
I have a westinghouse monitor L1916hw and my monitor was fine last night but this morn when I woke up the lighting was flickering and then went black and when I turned it off and back on it will stay lit...
Get in the habbit of turning off LCD monitors when not in use. First, save electric. Second, save your monitor as LCD will burn up faster than a CRT. As for your problem, I would assume it's burning out and/or about to burn out...overheating. I would shut the entire system down, let is sit for 5 minutes and reboot everything. If it still fails to strike properly, it is probably toast.
Jun 29, 2010 | Westinghouse Electric L1916HW 19" Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Stuck on logo screen
I hate to tell you, but that is bad news. But before we jump to any conclusions, first open up the computer and look for the BIOS reset jumper on the motherboard, if you find it switch it to clear CMOS for around 20-30 seconds and then put it back on normal and see if it boots. If it doesn't, there isn't much more we can do, as your motherboard most likely decided to keel over and die.
Apr 09, 2008 | Medion MD-1704 PC Desktop
HP won't power up
Your main board is having a problem.
Nov 16, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Blank screen
Similar monitor, similar problem. I actually had to dismantle the thing and replace a transistor on the mainboard.
If you're not into soldering and such, good luck.
Oct 03, 2006 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
613 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
