Question about Sharp AL 1631 Copier
Blinking jam lite. The instant of power.
Need the svc commands to test individual switchs and command to get into svc mode. charles
  • vw driver Jun 10, 2008
    forgot to mention, there are no paper parts in the mach. you can see thru all portions of the mach.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats your email address?
    Where is the jam appear to be at?
    Ususally the scanner is the culprit. Usually caused by the ribbon cable jamming in the scanner section.
    You might want to take the scanner apart and check that out.
  • Sharp Master
  • 2,794 Answers
The service mode is a little bit primitive on that machine for testing switches.
You can visually inspect the problems on that machine.
Posted on Jun 11, 2008
2000 le sabre, power windows, door locks, side mirrors, not working all of a sudden
All - driver - passenger - front an back ? Look for broken wires inside the rubber boot from the body to the door ,driver side !
Power Windows Operation
Power Windows
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
If the status information to permit window operation is correct, the DDM sends the command to the door module controlling the window to move the window as requested.
Windows Power and Ground
The windows are powered by discreet power and ground circuits. These circuits are in the same dedicated connector as the window motor drive circuits.
PWR/WDO 30 amp circuit breaker located in the rear fuse box ,DRVMDL fuse 10amp located in the same rear fuse box . This power the driver door module (computer )
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door. The driver door module (DDM) is the master control for the door lock system but the rear integration module (RIM) contains the program that determines when the lock functions are permitted.
The exterior key cylinders are wired to either the DDM or the passenger door module (PDM), depending on the location of the key cylinder. The interior lock switches are wired to the driver door switch assembly (DDSA) and the PDM. The DDSA and the PDM send the lock switch requests to the DDM over the simple bus interface (SBI) serial data circuit. The DDM then sends the lock requests to the RIM over the Class 2 serial data circuits.
The door lock operation modes are controlled by the rear integration module (RIM). The RIM examines the requested function from the DDM, or the remote function actuator (RFA), as well as the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. The RIM determines if a locking function is permitted, and commands the DDM to perform the function permitted. The DDM then sends commands to the rest of the door modules via the SBI to implement the selected locking function.
All programmable modes of lock system operation are stored in the RIM. The RIM checks the lock function program selected against the lock requests, the transmission selection and ignition key switch condition to determine if the requested function is permitted. If the requested function is permitted, the RIM then commands the DDM to perform the lock function over the Class 2 serial data circuits. The DDM commands the individual door modules to perform the lock function over the SBI serial data circuit.
GOOD luck your going to need it !
Mar 13, 2017 | 2000 Buick LeSabre
How to give test print through command prompt in windows-10.
you can print a test page from the command prompt using this command:
rundll32 printui.dll,PrintUIEntry /k /n “\\atl-ps-01\color-printer”
If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
Jul 01, 2016 | Matrix Office Equipment & Supplies
Cisco 3750 web config
Yes, know more about the Cisco 3750, just visit: http://www.3anetwork.com/cisco-catalyst-3750-switches-price_c41
Dec 26, 2013 | Computers & Internet
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
Wrench (repair)light is on. It's a Lanier 7313.
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Can't get into test command mode
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
To cancel the test command mode, press the [CA] key.
H4 00 Content Heat roller low temperature detection
Detail The fusing temperature does not reach 185°C
within 27 sec of turning on the power, or the
fusing temperature keeps at 140°C.
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check
and
remedy
Use TC 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use TC 14 to clear the self diagnostic display.
Feb 03, 2009 | Sharp AR-168D Black and White Copier
Sharp AL 1631 Copier Logo
198 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
