Question about Maytag Refrigerators
My mother has a MTB2456AEW serial number 11188491SS and it is leaking down the back of the inside fridge cabinet. I need a diagram of this fridge so I can order the needed parts. My family ran an applicance buiness for several years and I know what I need but need the diagram to order.
    Genius:
  • 1,073 Answers
Go to www.apwagner.com and you can look at the blowup of the fridge
Posted on Jun 10, 2008
Cant find serial # on GR-620RW fridge. it's not on sticker on inside of fridge. It says refer to bar code
Hello there,
There are different places to look out for your serial number. The bar code, it refers you to is the picture that is composed of just lines, it has some numbers written under it. That is the serial number of the refrigerator.
Here are a list of places to look at for the serial number:
  1. On the cabinet door jam,
  2. on the inside left or right wall of either the refrigerator or freezer,
  3. Behind the kick plate
  4. Behind the lower crisper drawer,
It sometimes used to be at the bck of the refrigerator. The part that faces the wall.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | LG Refrigerators
Water buildup in fridge
Same problem ...same fridge, different serial though.
Drain tube is blocked, but you'll have to take off the back panel inside the freezer, and look at where the drain tube is (usually centre).
the plastic/surrounding opening of the drain tube in our case was starting to rust out, allowing the leak to persist.
special silicon sealant worked for about 1.5 years, but the insert that is inside the freezer should be replaced.
no you can't get an insert they're not available
Apr 12, 2010 | GE Refrigerators
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
Aug 27, 2009 | Refrigerators
SERIAL NUMBER UN-READABLE ON MAYTAG REFRIGERATOR MODEL #MTB2456AEW. NEED SERIAL NUMBER FOR PART REPLACEMENT. ANY SERIAL NUMBER FOR THAT MODEL WILL DO. THANK YOU. AL. M
Al have you tried the appliancefactoryparts.com site to locate the parts you need, at that site you only need the make and model to access the parts list
Jul 30, 2009 | Refrigerators
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Mar 28, 2009 | Refrigerators
Refrigerator not cold; freezer very cold and forming ice on back.
The refrigerator has a number for example 312.57894 located near bottom behind fresh food door. Look at following areas for the model number
  • Let me know what you find, Sea Breeze
Mar 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge is not keeping cold
I will need a little more information to help you better,
Thanks, Sea Breeze
Mar 26, 2009 | Refrigerators
Fridge gets no air flow, freezer works fine
Air from freezer could also be restricted. Need you to find me the correct model number.
  • Thanks, Sea Breeze
Mar 24, 2009 | GE Profile Stainless Bottom-Freezer...
Refrigerators Logo
175 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
