OUR WESTINGHOUSE 32" HDTV WHICH COST US $1100 DOLLARS 2 1/2 YEARS AGO PICTURE TUBE OR WHATEVER IS IN THERE HAS FAILED AND I HAVE BEEN TOLD THAT IT IS PROHIBITED BY COST TO REPLACE. I CAN NOT BELIEVE THAT A PRODUCT WITH A RESPECTED NAME LOKE WESTINGHOUSE WOULD ONLY LAST A COUPLE OF YEARS WHEN USED ABOUT 6 HOURS A DAY. PLEASE ADVISE ME IF THERE ARE ANY REASONABLE RESOLUTIONS TO MY PROBLEM. I MIGHT ALSO ADD THAT I AM A STOCK HOLDER OF WESTINGHOUSE STOCK FOR MANY YEARS AND AM ASTONISHED THAT OUR COMPANY WOULD PRODUCE A PRODUCT OF SUCH LOW QUALITY
That is an unfortunate situtation you are in, but you need to understand Westinghouse does not make or manufacture the TV or is components in your TV. They are merely doing what is common in the industry which is rebanding.
$1100 is a lot of money for a 32" LCD so I do not blame you for being upset about the problem you are getting and the service you are experiencing. But the fact of the matter is, there are 32" LCDs on the market today that are starting at $499.99. You can always purchase a more expensive name brand also, but in the end you should consider a replacement warranty or if you put it on a Credit Card, verify whether your Credit Card does automatic warranty extensions....
Posted on Oct 13, 2008
I am looking for a picture tube for a proscan TV 32"
I believe they are no longer available. The last tv picture tube was manufactured several years ago. To cross reference you will need the actual part number and a lot of luck running across one laying around in some shop.
Aug 04, 2016 | Proscan Televison & Video
No picture sound only, blue light stays on
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!&^%
Feb 22, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse ltv-46w1hd I have sound no picture was advise it could be the backlight inverter how can you tell if it bad.
I have a Westinghouse 46" LTV-46w1 HD and it turned out to be the T-Con board which I found a used replacement board at Shop Jimmy’s. It cost around $70.00 with shipping. My TV was purchased in 2006 and it running better than ever… again!
May 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Sep 16, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Blue tint on bottom of screen
I have the same KDF60XS955 sony and have the same problem. I called sony customer support and was told there was a recall on the optical block for this tv. But the recall ended in Dec. of 2008. I was upset that they did not call or send out a notice to me. They should of had my information because I had a different issue that they sent someone out to fix a few years ago. They said it was an expensive fix, like over 1000 dollars. Instead of fixing it they offered me a deal on a smaller tv, a 52 inch sony. I could buy that one at a discount which is about 1100 dollars. I told them that I thought that was the worst deal I have ever heard of. Why would I spend about 4000 dollars for a tv 4 years ago only to be told that I could buy a smaller one today for 1100 dollars more. I said if I bought that 52 inch tv today, what would happen 4 years from today, am I going to be offered an even smaller one for more money again? I thought I was buying a top of the line tv back then, I only wished it would have lasted longer than this. Not happy!
Mar 16, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a 52" hdtv by rca. We have had it for 2/12 years with no problems and now we turn it on and the screen is showing all 3 colors (red, greed, yellow) in different lines at the top of the screen...
Your 52" TV does not have a picture tube. It is just a thin screen that is either plasma or lcd (liquid crystal diode). Anyway it sounds like a driver has gone out. RCA is not as reliable as it used to be years ago. If you can locate a TV repair shop locally you can take it there and have them give you a quote for the repair. These large TVs are getting to the point where they are ALMOST considered disposable. If your quote is over half the cost of your TV I would recommend you get a new one. Sometimes the repair shops will buy your dead TV for a little amount and then they use it for spare parts. I hope this helps you. I know these things can get spendy but you are at the time of year when TVs are about to come on sale. Sorry for the bad news.
Nov 09, 2017 | Televison & Video
New HDTV bulb
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
Jul 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Sanyo 32" hdtv
CRT socket is the the problem of your tv,so change the socket.it is a white plastic with a 7 or 9 pins that attach to the picture tube
Jul 12, 2008 | Sanyo HT32744 32" TV
Turns off automatically after 5 seconds. Momentary display of saturated picture and sound from memory. Brief menu display, superimposed on screen. Could this have been caused by a spike on the cable...
mine did that too, turned out a picture tube went out on it. I was told that it probabely was a sensor that was turning it off. the picture tube, I was told, would cost me over 600 dollars
Jun 23, 2008 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
