Question about Sanyo Lands Phones
Sanyo Super Compander 3 CLT 4350
The antenna wire is broken off from the circuit board.
Where does it attach?
Is a circuit diagram available ?
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
Posted on Jan 14, 2009
  • 128 Answers
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Posted on Aug 30, 2009
SOURCE: Hook up old tv antenna to converter box
how can i connect inside anntena to the tv and converter box?
Posted on Oct 16, 2009
dave1645
  • 834 Answers
SOURCE: i need a power cord for my santo clt 1554
you should be able to find one at Best buy
Posted on Nov 25, 2009
HOW DO I FIND THE INVERTER BOARD NUMBER FOR THE SANYO CLT1554 FLAT SCREEN TV?
Open up the TV and trace back from back lights to the circuit board!
Dec 30, 2014 | Sanyo Televison & Video
Can i connect an external antenna to a sanyo awm 2000u stereo for better tuner reception?
Your stereo came with a piece of wire attached at the back. This is/was the FM aerial. It should be roughly 1 metre or approx 38" long. There is no socket on the back of this stereo to attach an external FM aerial. So if the wire broke off then you're going to have to either attach some new wire to the stub, or open the set up and solder directly to the circuit board.
The exact cable lengths for an FM antenna to pick up 88-108 MHz is 37.66" long.
Sep 12, 2014 | Audio Players & Recorders
I have a Sanyo Compander plus mode; CLT-1861 bouth 15 years ago. I lost the instructions on how to program phone numbers into it. Will it be possible to get them back................ Thanks. Carole
to store numbers.
1 press memory.
the talk indicator flashes.
the dialing buttons light for approximately 10 seconds.
2 dial the phone number you want to store.
3 press memory.
4 press a number ( 0-9 ) to assign a memory location number to the phone number.
a beep sound. the dialing button light goes off.the phone number is now stored in the hanset memory.
5 repeat step 1-4 to store other numbers or to change previosly stored numbers.
my name is jean( french for john) e-mail is morin.j2@videotron.ca
Sep 18, 2011 | Cell Phones
Sanyo cordless model no CLT-79 a peep sound comes when i press the call bottom
Sir, I've lost hand set of SANYO CORDLESS TELEPHONE and modle no. is CLT-79, How will i get the same ? pl. hlep.
Oct 28, 2010 | Sanyo Cell Phones
1987 Volvo 240 DL...hard-wiring the brake/tail lights...
Solder to the circuit board, just in case they interact with other circuits.
Aug 03, 2009 | 1991 Volvo 240
Sanyo clt 2054 dead.just a clicking sound, no picture no sound no power light. replaced main board same problem.
As there is no Power, there seems an issue with Power Supply. Might be a blown capacitor.
Do you hear any sound when you Plug on the LCD and the Button?
What i assume, it has to be the Faulty Power Supply Board. As you are not getting any power , you should have check the power supply board followed by main board .
Check the Power supply board and invertor circuit and replace it, if Faulty.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Televison & Video
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
AM/FM stereo receiver often fully "drops" the reception of listened to radio station(s), or reception will often decrease in volume. Repositioning of the receiver's connected antenna wire often has no...
Possible solution. I have fixed two with this problem. When the radio drops to a hard surface, the ferrite coil antenna is the heaviest component on circuit board. Look for cracks in solder or broken wires where attachments to circuit board occurs for this component. Use a fine point soldering iron with low heat.
Oct 12, 2008 | Audio Players & Recorders
Sanyo CLT 947
Two solutions. Replacement rubber key pad membrane or re-apply conductive coating.
1) Call Sanyo and see if they have a replacement rubber membrane keypad for your model of telephone. (I replaced the keypad membrane on my Sanyo CLT-2430 cordless phone). In Canada, the Sanyo telephone number is: (905) 760-9944. Their web page is: sanyocanada.com.
2) A rubber keypad repair kit is available from MG Chemicals. Rubber Keypad Repair Kit 8339.
This kit is described on their web page: http://www.mgchemicals.com/products/8339.html
In Canada, this keypad repair kit is available from ElectroSonic. See a description of this kit at: http://www.e-sonic.com/acc/products.aspx?command=detail&partID=8339&partIDExt=281
In Canada, this keypad repair kit costs about $14.00.
Apr 22, 2008 | Sanyo CLT-A902 Cordless Phone
Lands Phones Logo
422 people viewed this question
Top Sanyo Lands Phones Experts
Tre Elkins
richie46
Computer Repairing
Computer Repairing
Are you a Sanyo Lands Phone Expert? Answer questions, earn points and help others
