Question about Canon PIXMA iP3000 InkJet Photo Printer
Computer cannot detect printer
I recently re-formatted my computer, i installed the printer..then it happens printer cannot be detected...im using the iP 1300 it used to work well. But now nothing. When I try the roller cleaning it functions, but thats all it does. It doesnt print anything at all... I HAVE THE INSTALLER cd it gets stuck at 33%. Tried to download driver to no avail... what should I do..
  • Canon Master
  • 5,568 Answers
Try this:
Go to the Control Panel, then open Printers and Faxes.
If your Canon is listed remove it by right clicking and deleting.
Check Add and Remove software to see if any part of Canon’s software is listed and delete it if it is.
Leaving the printer on and connected, restart your system.
This should force Windows to recognize the printer and install a compatible driver from its library.
If successful, choose some document to print to see if the printer is now responding.
If this is also successful, then try reinstalling Canon’s software to regain access to special features not part of the Win driver.
Reformatting your drive is often not necessary and can cause the kind of problem you are experiencing; Restore works pretty good in most cases unless you picked up a really tenacious virus and couldn’t remove it any other way.
Posted on Jun 10, 2008
    Problem Solver:
  • 14 Answers
What is the operating system of your computer?
Try to connect the printer to a different USB port.
Hi Im using the printer for the first time on my computer. the comuter detects the printer becuase it says that the usb hub detects it. the green light is on the printer but what do i do to get it...
You need to install the software and the drivers to make this printer working. Normally it comes with the set up disc. IF you did now recieve one, you can check the printers manual and support site HERE
Oct 27, 2010 | Dell 924 All-in-One InkJet Printer
Modem not detected
check your computer , the PCI device listing says simple comm controller. check your modem device manager see if its visable and not a question mark in the device manager
Jun 08, 2010 | Conexant chipset 56K V.92 PCI Data/Fax...
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
Hello.. ive had this computer with vista as its operating system, because im not used using vista ive reformat it to windows xp pro but after formatting screen goes blank.. what could be the problem?? the...
There likely may be no XP Drivers for this model. If thats the case your choices are Vista or Windows 7 (Windows 7 Only if the system is capable)
Friendly, affordable, REMOTE computer help!
Nov 23, 2009 | Computers & Internet
Pendrive is not detecting
Try to enable your usb ports in Setup mode...
Try to test your usb port with another pendrive...
Reinstall your USB motherboard Drivers...
re-format your pendrive with a hp flash format utility....
Good Luck!
Dec 05, 2008 | Gigabyte GA-8IDXH Motherboard
HELP! my computer cannot locate my scanner
When you downloaded the driver, did you make sure it was for the specific moder scanner that you have?
From the control pannel of your computer make sure that you added the cannon driver to the computer, you have to select
( ) cannon driver. I tmust be the spacific model name and number on your scanner.
The scanner must be on, so you can start test scanning . Why is not ON?
Finally after you done this avobe, If it doesn't work, the problem might be the cables.
Artgirl
Jul 12, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Crappy nokia n70
To format a memory card on the N70:
Menu/Tools/Memory card,open it, Options, scroll down to Format memory card.
May 23, 2008 | Nokia N70 Cellular Phone
Songs Not Loading On Player
Did you use Windows Media Player to format?
WMP never does a thorough format.
If so, try formatting thru My Computer. Right Click on the Device (e260) and select FORMAT.
Then try transferring your music again.
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e260 MP3 Player
USB Problem in installing Canon PIXMA MP160
the USB cable you are using may be of poor qualit. Try a USB2 compatible cable that is thicker.
Sep 14, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
89 people viewed this question
old marine
old marine
