Question about Xerox CopyCenter C118PL Copier
Trublshuting the copier shows system unavilable message and it will not copy (the machin is copycenter 2
  • 81 Answers
Try turning off and unplugging the machine for a couple of minutes, then starting it up again. There is an underlying code. If you can find it, I may be able to help more.
Posted on Jun 10, 2008
If the hp 3310 printer is out of two coloured inks would it show the message "ink system failure"?
being driven mad with a stupid "Ink Expiration Near" message show up on HPPhotosmart 6100! ..... and two printheads each dealing with 2 of the 4 coloured inks.
Apr 14, 2014 | HP Photosmart 3310 All-In-One InkJet...
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
I get "system error e000" message when i copy
1) Press the "Additional Functions" key.
2) Press the "#" key.
3) Press > to the "#7" printer function.
4) Press the "Set" key.
5) Press > to the "#4 Printer Reset".
6) Press "Set".
7) Press 8) Unplug printer, plug it back in, and turn it on.
Mar 14, 2011 | Canon Image Runner 1630 Copier Copier
My Workcentre 7345 has a Fault Code 012-350
Make sure the cable from the Finisher is connected to the main section of the machine.
Feb 02, 2011 | Xerox Feeder Tray for CopyCenter C118...
The machine says my copier/scanner has failed to initalize . what do i do ??
This problem might need a Xerox Serivice Rep to repair the machine.
Sometimes the scanner motor fails, needs to be replaced.
The drive cable might be loose or have broken gears on the drive motor.
For indepth solutions, call Xerox, hopefully the labor and parts are included in the call charge. Xerox will warrenty the service for 30 days.
Oct 07, 2009 | Xerox CopyCenter C118PL Copier
Copy speed slow ( on bizhub c450 ) and show three angle shape
good luck
Description:
The machine copies very slow and well below the rated output for black and white and color.
Solution:
CAUSE: The machine memory is corrupt.
SOLUTION: Perform a data clear:
1. Browse to the NIC/Log on as Administrator/Select the Scan tab/Import Export and back up the one-touch addresses to the desktop.
2. Enter Tech Rep mode.
3. Select System 1.
4. Select Data Clear and press start. Wait for the machine to cycle OFF/ON and for the POWER OFF MACHINE WITH THE MAIN POWER SWITCH message.
5. Import the one-touch list back to the NIC.
6. Re-install the HDD and power the machine OFF/ON.
7. Reset the Marketing area to U.S. and the target to U.S.
8. Re-install the TCP/IP address and power the machine OFF/ON.
Sep 14, 2009 | Office Equipment & Supplies
Copying with a copycentre 255
Go to www.xerox.com , on the home page click Support and Drivers.
IN the search where it asks for a product name or number type in 255.
Then select the Copycenter 255 Documentation.
Then select either the QUick reference guide, which is most likely all you need. or download the training and information program.
Jan 01, 2009 | Xerox CopyCentre C123 Copier
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Xerox CopyCenter C118PL Copier Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
