Question about Samsung SyncMaster 740N 17" LCD Monitor
Samsubg Monitor flickers
Can anyone give me a fix for a flickering screen on a Samsung 740N 17" LCD Monitor? E-mailme at ouryoshi@comcast.net Thank you
  • Anonymous Nov 16, 2008
    Mines actually a 710n but the "fault" appears the same, every 5 seconds it seems to lose power and goes black for a fraction of a second. MOST frustrating !!!!!!!!!!!
  • design2host Mar 16, 2009
    I have the same problem with the Samsung SyncMaster 740n Cant seem to find a solution. It happens only when the screen is refreshed (as in when you type something, there is an animation playing etc). When there is no activity on the screen there seems to be no problem. Tried play around with the refresh rate thing by sqitching from 60 hz to 70 and 75... but no luck. Any suggestions?
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Posted on Nov 05, 2008
  • 26 Answers
It could be the capacitors on your monitor's Power Supply. Open up the lcd and check the power supply board see if you see any "BULGED UP" capacitors. If thats the case you most likely just need to replace the bad capacitors. Go to radio shack or electronics supply store buy the same capacitors with the same mF and volts. If you can't find the same ones then always go with higher voltage. Replace the bad ones with new ones following this video. Make sure you note the negative terminals on the CAPS before you remove them. The shorter side on the new CAP is always negative.
Posted on May 03, 2009
  • 558 Answers
Check the capacitors inside see if they are blown
Posted on Jun 19, 2008
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor's backlight flickers whenever switched on....please help me.
You need to do two things. First, switch out your monitor input cord (the blue one) and get a new one. If you don't have a new one, then unplug both ends and make sure none of the pins are bent or broken. Then plug and screw in completly. If that doesnt work, google your monitors name and drivers, and redownload the drive for it. It should take you through a repair proccess which should fix it
Sep 05, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Auto adjustment locked and picture is fliker
Its not auto adjusting because of the flickering. Its flickering because the screen itself is losing voltage so it cant stay on. You can try hooking up the monitor to another computer just to rule out a bad video card but it looks like replacing the LCD is the only solution.
May 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung sync master 740N no display. Flickered started then the display goes after its been on for a short wile. Could this be a problem with the capacitors?
Yes, look for two 1000uf capacitors on the power supply PCB near the output cable to the main PCB. They will have swelling and discolouration. Replace those and should fix your problem.
Oct 06, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
SyncMaster 740N 17" LCD Monitor: I have two of the SyncMaster 740N's as security mo...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
There is lot of disturbance on the screen
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Nov 03, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsubg 17"LCD 740N monitor flickers
It sounds like the CCFLs (backlight lamps) in the monitor are failing. You might be able to get them replaced by the manufacturer if it's still within warranty. Otherwise the fix might involve an expensive technician and replacement parts.
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
581 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
