Question about Compaq Presario SR1000T (568657) PC Desktop
Pc will not turn on
Pc only turns on for 3 seconds then goes off fans are running but screen does not come on
This is the problem of v.r.m section of your mothher this problem
may be also because of i/o controller chip
s.k.
Posted on Jun 10, 2008
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Touch screen on acer z290 goes blank after 2 seconds
mine after few second turns off.
cpu remains cod and fan is working and nothing getting hot on matherboard.
Feb 23, 2012 | Acer Veriton Z290G 185 320GB
I turn on the power switch, led lights, fan run, but after few seconds it turn off and no display on the screen, as in blank/ no lights
Have you check the battery and the power cable it is it charging? What happen before it goes like this?
Jan 05, 2011 | HP Computers & Internet
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
When i turn on laptop,power light comes on, fan comes on for about 3 seconds then goes off, no screen
ok try removing the battery and plug into wall socket. try to boot the computer. if it boots up without this problem you will need to replace the battery.
Nov 11, 2009 | Acer Aspire 5315 Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Battery Charge and shut down
there's is some problem with the bios setting set the bios setup to default setting to get back to its stable settings
Oct 10, 2008 | Toshiba Satellite M35X-S349 Notebook
When pc start the processor then turning vey fast for 3-8 second the pc turn off by itself
How you know the processor started state clearly are you talking about the processor fan starts running????
Jul 24, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Screen goes black but computer is on
I would turn the computer off at night, but try to restart the computer. the computer can get stuck in a suspended state of "hibernation" and due to a program error or a corrupt file it can get stalled this way ( just like when your computer freezes)
Dec 29, 2007 | Dell Dimension 2300 PC Desktop
Compaq Presario SR1000T (568657) PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
