Question about Aiwa AV-D97 Receiver
Aiwa AV-D97 Power Issue. Just clcks when you hit the power button
Saw an old post about this problem. Loved this system until recently. Now, when you prress the power button, all you get is a "Click sound". Unplugged speakers on at a time to see it was a Speaker Ground issue. NOPE...Any quesses other than tansformer shot ?
  • fixall6 Nov 10, 2008
    aiwa av-d97 only power to the on light. nno power beyound that. Where can I take nit to get fixed and is it worth it?
  • 4,234 Answers
The unit is most likely in protect mode. This means that the output section has a problem and the protection circuitry is preventing it from being turned on. This is to prevent further damage. The typical defective parts are the output transistors. Figure on $20-$40 for parts plus the local labor rate for repair.
Posted on Jun 10, 2008
When you press the power switch - power - only switch, the relay is opened again and the unit will not start.
check the secondary power supply the voltage regulator and the filter capacitor..i have encounte such prblem and found the filter capacitor is is leak almost shorted..hope it help
Apr 30, 2011 | Aiwa AV-D97 Receiver
My Aiwa AV-D58 receiver won't turn on, only sits on 'Eco Mode.' After letting it sit for about a month, i plugged it into a power outlet and it worked, so I unplugged it and carried it into the room...
Have someone check your house wiring to see if the live and neutral are reversed.
Beyond that - you may have some leaky capacitors. If you're tech savvy, open up the unit and see if any of the electrolytic capacitors are bulging at the top or leaking at the bottom, and if so, unsolder and replace them. This is actually the most likely issue.
Feb 21, 2011 | Aiwa AV-D58 Receiver
Does not power up.
You might try to find a reset button on the back of the unit. Also, the Aiwa website may have a "support" staff that can see if they have an archived manual or tell you which buttons to push. Also, check to see if the unit has a fuse in back. Finally, check a website called . It's a free deal where people exchange manuals and information.
Jun 03, 2009 | Aiwa Audio Players & Recorders
Why does the volume go all the way up when i put it to 15?
aiwa typical issue. loved my aiwa's sound hated the stereo. my volume control knob did the same thing and i had to order a new control.
please take time to rate,
good luck
Feb 16, 2009 | Aiwa NSX-DS55 CD Shelf System
No power
Does AV-D97 sounds click of relay when pressed power button?
Nov 03, 2008 | Aiwa AV-D97 Receiver
Power on problem
Well this helped me find the relay but I found that after i pulled it off the board that it has some corosion around the metal prongs that hold it to the board. Could not get the relay open to do what is posted above , tryed opening it several times. Not sure if you are supposed to open it but could someone let me know. I am scraping around the prongs to get the corosion off hoping it will help but might just replace it alltogether. Further info on how to open the relay to do what is posted would help, I would appreciate any help, plzzzzz! :)
May 21, 2007 | Aiwa AV-S17 Receiver
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Subwoofer output
There could be a number of reasons causing this malfunction, try replacing the subwoofer's cord, it might be damaged, you can also try reseting the system to the factory settings according to the following instructions: Reset Instructions: 1. Press the power button to turn off the power 2. Press the power button while pressing the ENTER button. (note: this will reset all memory) Good Luck
Jan 09, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-D97 Receiver Logo
397 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
