Question about Frigidaire Compact Air Conditioner
Timers cannot find a manual to tell me how to work the timer and sleep timer on my a/c --
  • 52 Answers
Go to manufacturer website
Posted on Feb 26, 2010
How do i keep the wifi on my epson wf2540 printer from going to sleep
  1. The Sleep Timer
    The product enters sleep mode if it is not used for a period of time. You can adjust the time period before sleep mode, but increasing the time reduces the product's energy efficiency.
    Changing the Sleep Timer Setting From the Control Panel Changing the Sleep Timer Setting - Windows
    Changing the Sleep Timer Setting - Mac OS X
    Parent topic: Product Basics
    You can use the product's control panel to change the time period before the product enters sleep mode.
    1. Press the [img src="file:///page23image5084" alt="page23image5084" width="15.095703" height="9.057693">button.
    2. Press the up or down arrow buttons to select Printer Setup and press the OK button. You see this screen:
& check the manual page 23
Sep 05, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
My sleep timer is on and i can not get it to turn off.
try looking the manual sleep timer off switch. you can turn it off through it.
May 28, 2009 | Quasar VHQ820 VHS VCR
The sleep timer do not work
call the custermer service the number is on the manula...tell them if they could help..
Mar 08, 2009 | Philips Magnavox 27MS343S 27" TV
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Sleep timer?
Sleep Timer option is available in remote only.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Nov 17, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Where is the sleep timer????
just checked a similar sets owners manual...the sleep timer on this model is located in the menu---setup,,this menu prompt has language,SLEEP,menu trans,menu timeout ,and default setting....if you don't see the SLEEP mode in setup--you probably don't have it!...hope that helps
Aug 20, 2007 | Initial DTV-322 32 in. TV/DVD Combo
Frigidaire Compact Air Conditioner Logo
187 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
