Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I have two problems with my washer...
1) Water always settles in the rubber door seal. I have to manually clean it/empty it because it gets mildewy and smells. I also have to leave the door open after a load to help avoid the mildew growth & smell.
2) We can only use the washer on "warm". Any other setting blows the circuit breaker!
  • 3 more comments
  • gulan Jul 02, 2008
    I have a problem with my front loader smelling like mold due to a small amount of water sitting in the rubber ring by the door. I think I have mold growing under it... I cannot wipe it out and continually spray with bleach and wipe out after a day's washing. I am not getting rid of the smell. Do I need to get a new washer?
  • twodogfox Jul 05, 2008
    I also have a horrible smelly hamper type smell in my Bosch Nexxt WFMC 3200UC. It seems to be way too much smell for just that water collecting around that seal. I also leave the door open after a load to make sure it dries out. I felt there had to be something molding under the drum as well for that smell. I have another brand of front loader at a second home and it does not smell.
  • TETRUCKING Jul 21, 2008
    I HAVE A FOUL ODOR IN THE WASHER THAT WILL NOT COME OUT ,AND THE RUBBER GASKET IN THE FRONT STAYS FILLED WITH WATER
  • flickie Aug 14, 2008
    The washer has a moldy smell even though I dry the gasket after doing a load. Foul smell. Had a small sock and nickle size felt piece sucked into the pump and needed repair. Never had any thing like this happen in my 50 years of washing.
  • Anonymous Sep 01, 2008
    mold on gasket in front-loading Bosch Nexxt. Tried scrubbing it with bleach
    Genius:
  • 1,028 Answers
Probleml 1 ..normal on ALL front loads problem 2 better call service sounds like may be wiring issue if you want to do a quick ck yourself remove top 2 screws on rear edge of top panel look for bare wires around fill valve possibly pinched wire to cabinet during build
Posted on Jun 11, 2008
Always have left the door open and faithfully have followed monthly cleaning cycles. I still have a musty odor and the gray seal looks disgusting. I wipe the washer and seal and inner seal drum all the...
have you been using the affrresh cleaning tablets and emptying the filter sump after you run a clean cycle ... if the washer seal thats suppose to be grey is black you can attempt os scrub it with vinegar and scouring pad but most of my coustomers end up replacing it when it get that far along ....
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal on my Ariston Aqualis AQXXF129 is mildewy and sludgy. I can't take it off to clean and I can't get to the parts that need cleaning.
Front loading washers will get mildew and detergent residue built up inside them, especially if you dont leave the door open after using them. They need to dry out when not in use. if you leave the door closed all the time, they never dry out, and mildew will take hold. Most manufacturers recommend a monthly cleaning by running an empty cycle with bleach on it's highest temp setting.
if you have neglected this, you may have to do it several times before the mildew will go away. once you get it clean, use an HE detergent, and leave the door open overnight after you complete your last load. After it dries out, you can close the door. Some of the new "eco friendly" detergents contain plant oils to replace the phosphates and surfactants in regular detergent. these oils will build up and cause a pinkish tan sludge inside the washer. If you must use them, you may have to do your cleaning maintenance more often to keep ahead of the build up. several companies now make a powdered cleaner for the inside of front load washers.
Nov 20, 2010 | Washing Machines
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
Clothes smell mildewy after washing and drying
This is a common problem with front load washers. Mildew tends to grow in these washers due to it use of less water than top loaders, often leaves dirt and soap residue on the machine. To help prevent mildew, wipe the door gasket, leave door and detergent dispenser open after wash. Wash once a month empty, with hot water and vinegar to kill the mildew in the machine.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
While I was ill our daughter in law over loaded the washer and now there is a moldy mildewy smell. I have cleaned the drum by running a load of bleach water with no clothes, but the smell seems to be...
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Mar 04, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My clothes smell mildewy. Why?
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
I have an Affinity Front loading washer model #ATF80000FG1. It has a sour mildewy smell to it when I open the door. The clothes come out fine but the odor is overpowering! Any ideas on how to get rid of...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 09, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mildew smell in towels after washing. Tried
Everything that you did was good and right. Front loaders have a tendence to harbor mold and mildewy smells by the nature of their design. Cleaning the pump strainer, and repeating the steps that you took woll take care of the problem. The pump strainer is located between the drum and the pump, behind the kick panel of the washer. The strainer is connected to the drum with a rubber hose. Open and clean the strainer. While it is open, peer up into the pump, and see if you can see any other debris in there. Remove al that you can, and reassemble the strainer. Wipe down the seal faces at the door with a solution of bleachy/soapy water, and run a 'sanitary' load with bleach in all dispenser cups. Dump 1 cup of bleach also into the tub prior to starting the empty load. Use the hottest water setting. After the cycle ends, run another empty load to flush all traces of the bleach from the system. This should take care of the issue.
Best regards, --W/D--
Aug 08, 2009 | LG WM-2277HW Front Load Washer
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
147 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
