Question about Denon AVR-2106 Receiver
Input signal clicks on and off 4308ci
I'm on my second 4308ci and i blew up three 988's the denons are **** if you ask me but doesn any one have a anwser forthe signal clicking off and on on every component i have digital or analog.?
  • 4,234 Answers
When you say the the input clicks on/off, does the sound cut out? I suspect that the protection circuit is kicking in. Can you please post the connections you have? # of speakers connected etc?
Thanks,
Dan
Posted on Jun 10, 2008
How do I connect the TVee 10 to a Denon 988 AV Reciever
If you want to listen to your TV through the receiver, you have to connect the TV;s Optical Output to the receiver's Optical Input.
Dec 26, 2014 | Denon Audio Players & Recorders
Ping/Green Bars on TV Display
I would first check and replace the cables to make sure you have clean signal. If that all checks out then I would consider putting in an amplifier in line to boost your signal. What is the distance you have on the cables all combined? Another thing to check in troubleshooting is to remove everything (cables) except the unit you are experiencing trouble with. If after all of this I would say your connection to your component itself is suspect.
Jan 27, 2014 | Denon AVR-4308CI Receiver
My DENON AVR-4308CI HOME has no sound. Everything comes on as it should and unit looks great but no audio comes out. It's had off and on issues since I bought it, but firmware helped with some. Now, no...
This may require quite a bit more info. Verify that there are no shorts in the speaker connections to the Denon - it has a short detection circuit that will shut down the audio amps in the event of a short. If you are using optical or coaxial digital input for you audio - verify that the correct digital input has been assigned to the component selected on the Source Select dial: Menu > Source Select > Assign > Digital. If this is an HDMI connection go into the HDMI setup menu and select Audio: AMP: Menu > Manual Setup > HDMI Setup > Audio > AMP. If it is set to TV the audio passes through the AMP without being decoded and goes to the TV instead: there is no 'Both' setting.
Oct 26, 2013 | Denon AVR-4308CI Receiver
Sound went out today. Mute is not on, and all
Does it think you have headphones connected? If you have headphones, check to see if they have sound output.
Jan 26, 2010 | Denon AVR-4308CI Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Sound and video goes out periodically for a a couple of seconds every few minutes. Power stays on, all sound and video stops.
I am assuming you are connected HDMI?
This is a common problem when connected with HDMI. HDMI checks for HDCP codes every three seconds and if it doesnt get the proper response from the devices or repeater (amp) it will drop the connection and ask again in 3 seconds. If it receives the proper key it will display the signal again.
Have you tried the firmware update? http://www.usa.denon.com/AVR-4308CIFirmwareUpdate-Web1128.pdf
I hate to say this but HDMI is not perfect yet so there may not be a solution to this except to drop your inputs and outputs to component video and digital audio. The only source that will be effected from a resolution stand point is a BluRay which can only display 720p or 1080i (not 1080p) when ran through component video.
Nov 08, 2009 | Denon AVR-4308CI Receiver
No audio from analog audio outputs on denon 988
When you use VCR or DVR out, you must also turn on the VCR/Video 2 Tape Monitor function on the front input select, then it will pass audio. IF you need further help, post a comment and I can pull the specs on your receiver and help some more. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
DENON AVR 4308CI
SORRY, I WANT HANDS-ON SERVICE HERE IN MY CONDO.
Aug 23, 2008 | Denon AVR-4308CI Receiver
Denon 4308CI power
Tienes un problema con los amplificadores de audio de tu aparato.
Mar 17, 2008 | Denon AVR-4308CI Receiver
Denon AVR-2106 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
