Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
It won't turn on again
I have a Sansa mp3 player, it's red, and i plugged it into my computer to charge it like normal, and it did. But, then when i unplugged it, it won't turn back on and i tried to plug it up again and it won't show up on my computer. i have used this computer before to charge it. i have taken the battery out and put it back in and still nothing.What can i do? it has never been dropped. i was using it yesterday and it was working fine.
  • Anonymous Jun 20, 2008
    I have a black mp3 but it the usb doesnt want to work. It doesnt either want to turn on.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    My sansa mp3 player will not turn on
    This happened to me today, which was what brought me here. Also, when I plugged it in to recharge, my computer didn't even recognize it. The SanDisk troubleshooting said to hold up a power switch, which I didn't have, for 20 seconds. So I held the power button down for 20 seconds. (Much longer than the usual amount of time required to turn on). At first I thought it didn't do anything, but then when I pressed the power button again briefly, my SansaClip woke up, was recognized by my computer again, and in every way behaved normally.
    Jul 10, 2010 | SanDisk Sansa Clip MP3 Player
    Sansa Clip through the washer
    i did the same thing and it did the same thing yours did. but left mines connected for a week just because I forgot about it. and lord behold it worked again.
    Jul 01, 2010 | SanDisk Sansa Clip MP3 Player
    Wont turn on unless plugged into computer
    Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
    Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
    SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
    There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
    1. plug the payer into your USB port. or wall charger
    2. switch thje palyer on using the mechanical switch (on the side)
    3. turn it off by either holding down the play button, or selecting "System" from the menu
    4. The screen will go black and the battery will begin charging.
    Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
    My sansa wont turn on
    well did u make sure it is fully charged if so den plug it into the computer
    Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
    My mp3 sansa won't turn on or charge.
    If it freezes up, wont charge or just wont turn on... slide the power button up for 15-20 seconds then turn it on. That should work everytime. good luck
    Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Computer in Hibernation mode
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    My c250 turns on, but not in the way I would like it.
    Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
    Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
    21 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
