Casio CTK520L Electric Piano
Hi there, we have an electric Casio Piano model #CTK520L. The AC adaptor is broken and I was wondering where or how we could order another one.
  • light0564 Jan 23, 2009
    Help! The keyboard of thecasio CTK520L given to me by my friend is in japanese. Will somebody out there enlighten me about the functions of each key?
I WANT THE SIT OF MORTHER BOARD KEYBOARD CASIO 671
Posted on Dec 09, 2009
Here, this should work for you!
http://www.nextag.com/casio-keyboard-ac-adaptor-ad_-_5/search-html
Posted on Jun 11, 2008
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
My Privia px200 won't turn on, what is the problem
First get a new 12V DC power supply (AC Adaptor model AD-12) to test.
Otherwise it needs repair by Casio technician. Main PCB board may need to be replaced.
May 29, 2014 | Casio PX200 Privia Digital Piano with...
Why does my Privia px200 won't turn on?... is the adapter the problem.
Use a multimeter to test the AC Adaptor (AD-12) for DC 12 volts. If no voltage buy a new one.
May 29, 2014 | Casio Music
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Does the casio AD A12150LW MAINS ADAPTOR HAVE A FUSE INSIDE
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
May 27, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Casio keyboard ctk 2100 won't turn on
Do you have dead batteries, remove and use the adaptor only - try again.
Oct 21, 2012 | Casio CTK-2100 - 61 Key Portable Keyboard...
I have a Casio Privia PX-110 electric piano. The volume control is not working properly. How can I get to it to replace it?
Beofore you replace it, if it is only scratchy give it a good working by sliding it back and forth a rew dozen times. (if it is a slider type) If you can get some electrical contact cleaner with a thin plastic tube, try squirting that into it and work it again, if that fails, then look at the volume control replacement.
May 05, 2011 | Casio 88 Key Digital Piano With Stand...
AC adaptors replacements
You will not have any Problem What so ever.
18V is operating Voltage,
0.7A is Max of Current it (Power Adapter) is providing.
The Load (AR) is operating (Uses Current) between 0~0.7A (Even Less)
Therefore 1A Adapter is actually safer to use.
Think as, your electric company supplies 100A Service,
and you have only AC is running at 10A.
May 21, 2008 | Audio Players & Recorders
Computers & Internet Logo
481 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
