Pentax Optio S40 Digital Camera Logo
Posted on Jun 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power surge on USB port
The camera, an Pentax Optio S40, has worked fine for years. Now if I try to download the pictures on to a PC I get the error message "Power Surge on Hub Port, a USB device has exceeded the power limit.."
I tried the USB port in the rear of the PC hoping for more power, but no joy.
  • Anonymous Mar 29, 2009
    i have the same problem but with my webcam and my digital camera. PLEASE HELP.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
333
Points
Disconnecting other USB devices does not work. I contacted Live support on pentax site and they said issue is fault in circuit card in camera which requires shipping back, and paying for repair. They knew right away what issue is, so probably fairly common.
Work around is to copy images from internal card to memory card and then just use a card reader to get pictures. Thats easier or at least cheaper then sending in for repair.
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jun 10, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027644
Points
5636
This appears to be a PC problem-
Disconnect all other USB devices then try
Come back
1helpful
I get a memory card error message on my Pentax Optio S40. I bought two new memory cards. Sandisk 512 mb. I get the same message on them. I tried formating the card on my computer. When I pit it in my...
Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
1helpful
I want to upload pictures to my PC from my Pentax Optio S40 and I do not have the CD Rom with the S-SW16 software. Where do I go to download it?
Hi , you go to http://support.pentaximaging.com/nav/104
just browse in there you probably find wath you looking for;/ but if you have win vista it supposed you dont need any sofware vista should detect your cam
era....may be in configuration panel you can do somethings ....
hope that help you
Got a Pentax Optio S12. Can't print pictures onto
Use a card reader to download your pictures.
Sep 02, 2009 • Cameras
'USB Over Current Notice' unable now to download photos to computer
This is usually because the USB cable is shorting. Looks like an issue with the internals of the camera
Lost software disc
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "flash disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
here is the site for version 1.10:
http://drivers.softpedia.com/progDownload/Pentax-Optio-230-110-Download-16224.html
here is the site for version 2.1
http://driverscollection.com/?file_id=29747
i hope i was able to help you! good luck!
Power surge
Connect the camera whilst it is switched off....then when you power on...it will ask if you want to connect via PC or bridge....if that still throws up power surge...you need to use a different cable as the power ballast on the cable is faulty.It is much easier to just use a card reader....cheap off eBay.
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
