Mt 1050 I have been experiencing a problem..that involves the unit working for an hour or more,then i hear slight click in the front left side and it shuts off.I have checked the fans all are functioning and the filters have been cleaned.
32 '' lcd tv sharp is about 15 months old now shuts off after being on for atlest two hours , is there a problem ?
Posted on Jan 04, 2009
Where is the defrost timer on a mabe fridge
Hello Kristine:
My name is Peter. I am a retired field service refrigeration technician.
Good for you. The probability that you have a faulty defrost timer is extremely high.
A defrost timer will cycle every 8-10 hours for about 20 minutes.
It will shut everything down except for the refrigerator light.
Your defrost timer is white in color. In side it is about 2" X 3".
It is mounted on the backside of a sheet metal bracket. The are 3 screws holding it to the metal bracket. In the center of the metal bracket is a small hole slightly larger than 1/4". Protruding through this hole is a small shaft with a slot for a flat head screw driver.
I have never worked on your particular unit, however, the external mounting is generally the same. The defrost timer is either located behind the refrigerator, at the bottom, on the left hand side when you face the back. You may have to remove the lower bottom cover to expose it. The other location is in the front on the right hand side. You will have to remove the bottom grill (Toe plate) to expose it.
Now, having located the defrost timer and with a flat head screw driver, and with the refrigerator plugged in; slowly turn the shaft clockwise. You will hear a click. Turn the defrost timer slowly one click at a time until the refrigerator starts to run.
If this is the case then you know you have a bad defrost timer.
So, you must manually defrost you freezer. Say, every 9 hours, with your flat heat screw driver, turn the shaft on the defrost timer clockwise, one click at a time until the unit turns off. Time it for 20 minutes, then turn one click at a time to turn it on. A great job for a teenager. It would be fun.
Peter, Baltimore, Maryland, USA
Nov 02, 2014 | Refrigerators
Makes clunking noise
if the unit is sort of new and this is a loud popping (snap) noise, this is a problem with many models and manufacturers. It is a plastic part expanding and contracting during the self-defrost cycle. There is no fix, it is a common "defect" which manufacturers can't or won't rectify. The noise is loud enough to hear in other parts of the house.Good news is mine stopped making noise after about 6 months. It does not affect the performance of the unit. If this is not a newer model, this is most likely not the problem. Good luck
Oct 08, 2017 | KitchenAid Refrigerators
2003 cadilac deville driver window off track. motor seems to work but window will not go up.
Window regulator is bad in the drivers door . Do you know what a regulator is ? The Trainer 24 Power Window Troubleshooting Do you know anything about automotive electrical testing ? How to read an use a wiring diagram ? Do you know there are two side to a electrical circuit ? B+ voltage an a ground side . Plus there is electronic control modules and class 2 serial data network involved . When you push the switch for a window othen then drivers window on the drivers door . a class 2 message is sent to the other doors modules . The correct module will then open it's window .
http://www.bbbind.com/free_tsb.html Check out free wiring diagram here .Enter vehicle info . year , make , model and engine size. Under system click on body & accessories , subsystem click power windows . Click search button , then click each link one at a time .
Mar 27, 2017 | 2003 Cadillac Deville
2000 Ford Windstar front windows stopped operating, all fuses checked
I suggested you use some OBD2 scanner to have a detect. Very easy to use and very useful.
Jul 23, 2012 | 2001 Ford Windstar
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Replaced heater core. Mt car has the dual temperature zones. Now my passenger side temp wont change. stays hot, What should I do?
Either pass side actuator was not plugged in(rear most unit on heater of the 2 actuators for dual zone),(front unit which is an exact opposite is on the opposite side of the heater on the front side) or flap is jammed inside heater assembly.
Open the glove compartment and unscrew the door to remove.
Look to the left......remove the actuator and move the flap....if it moves and the unit was plugged in replace the actuator for the pass side.
Nov 08, 2009 | 1995 Buick LeSabre
When trying to roll down the window on the passenger side of mt 2001 vette,i hear a slight click sound,the lights dim a little and the window wont roll down ? help please.
it sounds like your switch is bad or you have a bad connection to it try pulling it out unplugging it spray some contact cleaner in the plug and then reconnect it
Oct 26, 2009 | 2001 Chevrolet Corvette
MT 1050 Lights, goes out then Status light error
I have the same issue with mine. Did you ever find a solution? Thanks!
Sep 17, 2009 | NEC MultiSync MT1050 Multimedia Projector
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Vibration and noise from front end while driving
Jack up the front end and put stands under it and block rear wheels. Look at axle boots and see if they are cracked. Try turning wheel back and forth sharply and see if you can hear any clicking. Problem could be outer axle joints. If the boots are cracked or you hear a clicking noise you will have to replace the axle. The axle and boot come as a complete unit. Please let me know what you find out.
Apr 13, 2009 | 2002 Chevrolet Venture Passanger
jasbo
jasbo
