Question about Bosch Dishwashers
When I switch on my Bosch dishwasher I can hear motor noise but no water comes through and the rotor arms are not moving. It's about six years old.
  • 3 Answers
Have you cleaned out the filter ?
Posted on Jun 10, 2008
Bosch shy66c02uc
JESUS ALMIGHTY
Dec 18, 2013 | Dishwashers
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1796FI Built-in Dishwasher
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
Jan 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch Classixx start problem
very possibly your wash motor is jambed. listen carefully when the water is in the unit for a hum. this is the motor trying to start.pull plug from socket then remove R.H.S cover to gain access to motor.at back of motor are cooling fins. if rotor is stuck, try and rotate untill free to turn.
Aug 29, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Aug 18, 2007 | Bosch 24 in. SHX33A02 / SHX33A06...
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
