Question about Panasonic PT-47WX5347 47" Rear Projection Television
Deflection Board I took my Panasonic PT-47WX5347G in for repair and was told that the D Board - TNP2AH046 - is burned out. Any idea where I can locate a replacement part? Thanks
  • WoodenBadger Jun 10, 2008
    Thanks for the quick response. Having trouble googling PTC. Any other info on the company?
  • 4,234 Answers
That part is no longer available as an entire board. It would be possible to repair the module or perhaps locate a rebuilt one. Check with a company called PTC. They rebuild modules.
Dan
Posted on Jun 10, 2008
Only see 3/4 of picture on my panasonic 47inch projection tv
If the remaining picture looks bright as normal then it sounds like the Horiz deflection amp has a failed component. Most likely a blown transistor or burned emitter resistor or both. Not to expensive to have repaired.
Oct 30, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Tried having the ic's replaced but still doesn't work
you need to get new board ..........because fixing will be very complicated and it will also be expensive ......
Aug 21, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Screen went black Panasonic TV/ PT-47WX53
Hello twisttolife,
What you have lost is horizontal deflection, this is caused by loss of the horizontal drive signal to the yoke transformers on the CRTs, for all three of these to fail at the same time is not likely so what I think is that the drive amplifier may have malfunctioned. To check this you will need:
1) schematic diagram or service manual (to determine the proper voltages and signals on the deflection board)
2) Multimeter (to measure the DC voltages on the components of the deflection board
3) Oscilloscope (to view the waveforms on the deflection board)
With these three pieces of test equipment you should be able to troubleshoot this problem.
Now if you do not have this equipment and what to take a chance at a blind guess, and just replace a board, I would suggest replacing the deflection board, this board usually contains the flyback transformer, the Convergence modules (which can cause this problem also), and the connections to the yoke transformers.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51DX80A
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Cicruit board for IC4511
I believe thats on the Signal board , but I dont have the schematics so I cant be sure, as all i have is the printout for the error codes for that model
Jul 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
D Board tnp2ah046
Hello WoodenBadger,
I do have the board in stock. Please contact me by email: boards@interactiverepair.com for full details on receiving the board.
Best regards
Jun 10, 2008 | Panasonic PT-53WX53 53" Rear Projection...
TNP2AH046 board
Yes. let me know to contact you
May 20, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence board
samsung convergence /deflection board has the flyback transformer and convergence ic's mounted on it you change it as a unit and must realign your convergence after if you don't have the service manual call a tech .
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Turns off 2-3 seconds after turning on-no red light?
sounds like a power deflection board issue its one board and it cost around 300 bucks its calld the d board i believe if it was just a cold joint solder it would be some xtra work trying to find the exact point but good luck
Jul 04, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
TV suddenly blanked (power is not off)
It is probably a burning deflection yoke.I just fixed an identical model with the same condition,Jim
May 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX5347 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
