Question about Norelco 8170XLCC Electric Shaver
Norelco 6846xl electric razor How to remove the rechargeable batteries to effect replacement.
kish-81
  • 3 Answers
SOURCE: I have a Norelco 6885XL electric razor that won't hold a charge.
It's easy - I replaced mine (Norelco 6885XL) with a soldering iron & batteries I found online. Here's one place that sells them:
http://www.electricshaverstore.com/get_list_145.htm
As these are NiCd, I always drain them totally dead, then recharge, as this type of battery does suffer from the "memory effect".
Dave
Posted on Jan 31, 2009
VtToolMan
  • 704 Answers
SOURCE: how to replace batteriers in norelco quadra electric shaver
The rechargeable batteries are solder into the circuit board of the electric shaver. You'll have to use a soldering iron to de-solder the terminals/tabs from the PCB (printed circuit board) in order to get them out.
Then you'll need new replacement rechargeable batteries to solder back into the shaver.
You can get teh correct replacement batteries from Electric Shaver Service in Lincoln, Nebraska (if you're in the US or Canada). They even do service and repair work in about a week, if you want to have them fix your shaver for you.
Here's a link to the battery page with your shaver model's rechargeable batteries for about $15.00 (plus s&h)
http://www.electricshaverstore.com/get_item_13810334_norelco-13810334-electric-shaver-battery-set.htm
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
  • 5 Answers
SOURCE: Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
Posted on Aug 23, 2009
brector3
  • 1612 Answers
SOURCE: I own a Braun Electric Shaver Model 6525 Flex
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Posted on Jan 16, 2010
brector3
  • 1612 Answers
SOURCE: Norelco 985rx Overheats upon charging..
You should always use the same type batteries that your shaver was designed to be used with. Your shaver was designed for use with NiCd batteries. If you have use NiMH batteries this may be causing the problem you described.
However, I would say that it is more likely that you have some sloppy solder that is bridging something that is not supposed to touch. You should check the battery solder joints on the circuit board and clean up any sloppy solder work that may be there.
Posted on Apr 16, 2010
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
How open norelco reflexplus 6 model 6863xl to replace the battery
Hi rafael110807,
This Norelco Razor contains rechargeable Nickel-Cadmium batteries, which must be
disposed of properly.
Batteries should be removed only when the razor is to be discarded. Batteries should be recycled or disposed of properly. To recycle the batteries please call 800-8BATTERY (1-800-822-8837) for a location in your area. If you have additional questions or need further assistance, Consumer Care can be reached at 1-800-243-3050. You can also visit this product's Support Site @ http://ow.ly/6j5Ep for chat, FAQ's, manuals, and more. Hope this helps. If so, let me know by rating this solution.
Sep 01, 2011 | Norelco ReflexPlus 6863 XL Electric Shaver
How do you remove and reinstall bartery-pack on Norelca 6846xl
You will find the correct battery pack for model 6846XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Feb 20, 2011 | Norelco 8170XLCC Electric Shaver
My rechargeable razor seems to be losing its charge quickly these days. Is is cheaper to replace the battery, or buy a new razor?
You will find the correct battery for model 7800XLCC at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you prefer to shop for another shaver to replace the one you have, you will find the entire selection of Norelco shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/rotary-shavers.html?manufacturer=4
Jan 07, 2011 | Norelco 7800XLCC Electric Shaver
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
My battery will not recharge
The battery has finally degraded to the point that it won't hold or pass voltage, so yes it needs to be replaced. Luckily, with a few skills, such as disassembly and soldering, you can remove and reinstall a new, rechargeable battery that should get the razor working like a champ.
Electric Shaver Service stocks most rechargeable replacement batteries for almost all electric shavers made.
Here's a link to the battery page, just find your model and you're ready to go. If you want, you can call and confirm which is the correct replacement battery for your specific model shaver too.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Aug 16, 2009 | Norelco Health & Beauty
I have a Norelco 6885XL electric razor that won't hold a charge. It will "recharge" to 44 minutes, but once below 39 minutes left it goes to 0 when turned on.
Dave
Dec 16, 2008 | Norelco 7886XL Electric Shaver
Norelco 8170XLCC Electric Shaver Logo
378 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
