Question about Dell 1710n Laser Printer
Dell 1710n paper stops moving - no obstruction
Paper feeds out of paper tray OK. Paper stops moving just as last edge leaves paper tray and front edge is 2 inches beyond last let of rollers.
Any advice?
    Guru:
  • 1,894 Answers
Then do a hard reset and try
Posted on Jun 10, 2008
  • dewan nafees ahmed Jun 10, 2008
    put a sheet in halfway through the manual feed slot
    while doing this keep door open
    doing it so u could make sure sheet went far enough so that the little
    two-pronged black flag right at front of the paper feed opening was
    kept pushed down by the sheet.
Does not take paper
If the printer won't "pick" the paper, open the back of the machine and look for torn pieces of paper obstructing the path. The paper should be all the way back against the stop so that the rubber rolls will contact the paper when the paper is lifted up against them. There should be no paper bunched up behind the access door. If the paper is against the stop at the back of the machine and the rubber on the roller wheels is ok (mine has three rubber rolls on the right side and one on the left plus a couple in the middle without rubber) then there is a possibility that the mechanism that moves the paper up against the rollers is not operating. You can observe the paper action with the back off by putting one sheet of paper in the tray. Watch as you press and hold the second button (paper) - the mechanism should lift the paper up against the rollers and feed the sheet out the back (because you have the access door off to view). If the paper is not lifted and taken out, the printer might be repairable by repairing the part that has failed - take the printer apart and look at the mechanism. I doubt that you can find parts for it so if it is not simple repair, it will probably cost too much to repair. The paper has to be far enough into the tray so that the rubber rollers catch it - for 8.5x11 paper, the paper should be a little over an inch from the forward edge of the tray when it hits the stop (the paper guide will be approximately 1/8 inch in from that same forward edge.
Jun 09, 2010 | HP DeskJet 810c InkJet Printer
Tip
Does not feed paper
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Turn on the printer (still disconnected from the computer) and try to feed paper manually (using the paper feed button).
Still does not work ? Go for Warranty or Service.
on Aug 29, 2008 | Epson Stylus C88 InkJet Photo Printer
I have an error E2. I have tried to reset the
E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed jams, and when tray is inserted, the top sheet is pushed forward and crumpled along the front edge.
sounds like you have something obstructing your paper path,before inserting the tray check to see if the sensor is freely moving,hope this helps
Jul 07, 2009 | Canon Laserbase MF6530 All-In-One Printer
Hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Nov 14, 2008 | HP LaserJet 1200n Printer
3210 paper wil not feed in the printer it not jam it just will not feed
If there is no torn paper or any obstruction then follow this
  • Place 20 sheets of paper in the printer ensuring none of the paper is torn .
  • Try to feed paper manually .
If your problem is not solved yet then follow this
  • Uninstall the printer driver and restart the computer.
  • Re-install the printer driver
SAM ANDERSON
Sep 16, 2008 | Computers & Internet
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Lexmark x3350
Feed the paper manually into the printer:
Place a sheet of plain A4 paper in the paper feed tray.
Move the paper support on the left-hand side to the left end of the paper.
Press the paper feed button.
If the paper does not feed, continue with step 2.
Check for any obstructions in the paper feed path:
Disconnect the cables from the back of the printer.
Open the front of the printer and check for anything that may be blocking the paper path.
Close the front lid and remove any paper from the paper feed tray.
Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Dell 1710n Laser Printer Logo
116 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
