Question about Xerox 8830 Copier
Maintenance scanner on Panel?
As soon as a Document is loaded the scanner doesn't work and the above message is displayed on the panel.
Could you please tell me what to do.
Thanks for helping
Thierry
  • thierryditle Jun 10, 2008
    Sorry the link doesn't work!
  • 81 Answers
  • diane szczesniak Jun 10, 2008
    I am not sure why the link does not work. Go to Xerox.com and select support. Then select wide format and select 8830 system from the product list. Click on support and enter scanner maintenance in the box. That should take you to the same page. It references cleaning the window and the feed rollers.
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
Tip
Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
on Dec 07, 2009 | Ford Windstar Cars & Trucks
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
Mar 30, 2011 | Office Equipment & Supplies
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Fi-6140-Rollers keeps moving even when doc feeder is empty.
There may be a piece of paper stuck in the sensor area, the scanner assumes there is paper and it keeps working. Blow gently and remove all shreds of paper.
S. Mohan
Aug 09, 2010 | Fujitsu fi-6140C Document Scanner Flatbed...
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Lexmark X422MFP Error 944
Removed CCD ribbon cable, cleaned edge connector and re-connected. Working well so far.
Jun 24, 2008 | Lexmark X422 All-In-One Laser Printer
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
