Question about Sony Ericsson Walkman W810i Cellular Phone
Keypad not working on wap
Hi, my keypad does not want to work when I use WAP, how can this be resolved, it works when not connected.
annest@telkomsa.net
    Brigadier General:
  • 7,752 Answers
That sounds pretty strange, take it to a mobile center and ahve the phone looked at..to see what is causing this
Posted on Jun 14, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
How to open smart gprs for my samsung star?
hi, if you are from philippines, you would want to do this... press message, then type this to your keypad. for SMART Internet settings,  type SET INTERNET  S5233 and send to 211, wait for configuration and install it to your phone.  go to your menu, press internet, select settings, select browser profiles, press the double arrow or >> to edit the acount, scroll down and select advance, check your static DNS to enable it and type the following server address to your server 1 ; 202.057.096.003 press save and exit the settings.
to configure your samsung star for wap or gprs,  you can do the same thing, type in your message SET GPRS S5233 and send to 211, wait for configuration, save it and make it as default browser profile.
if you want you can also do this manually.  1.   press menu 2.   select internet 3.   select settings 4.   select browser profile 5.   press create on the following boxes type this SET NAME ; SMART WAP BEARER TYPE : UMTS/ connection less (depending on your network) ACCESS NAME: WAP.SMART.COM.PH AUTH TYPE : NORMAL user id : smartwap password : smartwap protocol : WAP home url : www.smart.com.ph/wap proxy address : leave it blank linger time: leave it as it is press advance settings : check static ip address input this 10.102.61.46 leave static DNS. or if it ask,  check it and input 202.057.096.003
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
I need the mms settings for my samsung f480 for t-mobile here in the states.
Server Name: T-Mobile MMSC
Gateway: 216.155.165.50
Port number: 9201
Server address: http://216.155.174.84/servlets/mms
Cnnect via: My Work Network
Sending size limitation: 100k
WAP version WAP 1.2
You need to make sure that you have a connection under the My Work Network set to the apn name wap.voicestream.com.
OR:
Port number: 8080
Sending size limitation: 300k
WAP version: WAP 2.0
***Make sure the port# is 8080, and that this is set to default
For "My Work Network":
APN: wap.voicestream.com
Proxy Settings:
- This network connect to the Internet (checked)
- This network useses a proxy.... (checked)
- Proxy Server: 216.155.165.50
Jan 25, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Iphone clone p168
You need to do some setups for the internet.
For AT&T
Watch the YouTube video on internet setup for AT&T WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so there is no downloading java games. Copying them to the SD card won't work either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work fine. Make sure you have a good unlimited feature so you do not incur overages from over using your new toy.
For T-mobile:
This is the one that worked for me - I have the $5.99 TMobile Web plan:
Create Data Account
1. Select Menu
2. Select Entertainment
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
Create Profile
1. Select Menu
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
If you have the $19.99 or higher plan replace the following:
Step 7 under Create Data Account:
Optional - change name from TMobile WAP to TMobile "whatever"
Step 10 under Create Data Account:
use wap.voicestream.com or internet2.voicestream.com or internet3.voicestream.com instead
and
Step 9 under Create Profile:
Step 10 under Create Profile:
change to www.tmobile.com - may not work so try google.com also
SMS, MMS AND VOICEMAIL
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings--> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings-->click Server Profile
2-Click on any 1--> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
3-Data Account
click on GPRS--> choose Tmobile--> press OK
4- Connection Type
HTTP
5- Username
leave it blank
6 Password
leave it blank
CLICK ON DONE --> SAVE-->ACTIVATE PROFILE
VOICEMAIL:-
Edit it--> name No.1 Viocemail
No.2 +18056377243
NOTE:
Whenever the phone will ask you for a proxy address and port number.
You need that info to be able to get your sevice to work
Here is that info ...
Proxy: 216.155.165.050
port: 8080
Aug 17, 2008 | Apple iPhone Smartphone
How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Jul 29, 2008 | HTC Touch P3452 Smartphone
Samsung E250 wap won't work
hI Jaskaran33,
to have wap in cellular phones, I think that in your country is as in mine: we need to activate that service with our suplier.
call them and verify if you have wap activated or not. normally they activate it and send you a message with setup files wich automatically will be configured in your cellular phone.
complements
Jan 29, 2008 | Samsung SGH-E900 Cellular Phone
Connection to WAP
disconnect .
open internet browser
type the gateway and press enter
Nov 13, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Sony Ericsson Walkman W810i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
