Question about Sony KP-53XBR45 53" Rear Projection Television
Will not power up
I have a sony tv bought from somebody had really great picture one day all of a sudden we tried to turn it on and it will not go on, you would hear it power click like it was turning on the red light would blink but turn right off, and I read one of the solutions they had the check and clean all the connnectors and the tv is still doing the same, Does anybody know what the problem is and is it worth fixing,
  • 3 more comments
  • lourans Jun 19, 2008
    Sony rear projection tv. Was working just fine and suddenly we lost the sound and picture together. When pressing the power button on the remote control we can hear the switching sound from the TV but no sound or pictures. The front standby light keeps flashing when power button is press.
    Please help.
  • Anonymous Jun 25, 2008
    exactly the same problem
  • Anonymous Jul 04, 2008
    Turn the T.V on and the red standby light blinks once, and then nothing, as if tho it just shuts off. I know NOTHING of these t'vs and its my friends who I went to turn on and discovered this problem. HELP PLEASE!!!
  • JSoliday Jan 17, 2009
    I have a sony kp-53xbr35 56inch television that worked wonderfull untill i turned it off to go to bed. When i went to turn it on the next day i have no power to it. The stand bye lifht doesn't even light up. What could cause this?
  • rochelletere May 24, 2009
I had a similar problem. Look for a burned/shorted out capacitor on the main board. (It is marked J-something I forgot), 10mm diameter ceramic capacitor, 1000pF 20k SON116175400
It is about 3-4" from the left edge of the main board (power supply side), near the middle of the board. It is close to a large transistor mounted vertically on a cooling plate. It is a special high-voltage capacitor, you can find it online. Check the large transistor - it may be damaged too (mine was ok). After installing the new capacitor I got good sound and really weak picture. I called a repair guy who found a bad chip - after 3 hours of looking. The TV works fine ever since. As I learned, in most cases all you need is a new $5 capacitor. If you had a good picture before, it is worth the "investment" to fix this problem.
Posted on Aug 31, 2008
  • Laszlo Som Aug 31, 2008
    I found some more info I had written down. The capacitor's number on the circuit board is C514. Unusual, but Sony released no specifications for this capacitor. The 1000pF 20kV capacitor mentioned in my previous post was suggested by someone - and it works in my TV. Another suggestion I received later was: Sony model # 1-162-133-00, 390pF 2kV.
    The large transistor I mentioned in the previous post is the Horizontal Output Transistor.
Sony Bravia no sound no video?
its need tv up date soft ware please up date your tv
Jun 10, 2015 | Sony BRAVIA KDL32EX400 32" 1080p LCD TV...
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KP-51WS510 flickering&screen turning green????
Sounds like your focus block is going bad or out of adjustment. It could also be a bad picture tube.
Jul 05, 2009 | Sony KP-51WS510 51" Rear Projection...
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Jun 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony bravia kdl-46v2500
Dec 30, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KV32s45 sudden failure
I really have to say there is no miracle cure for TV's I have 20years of experience in fixing TV's I don't suggest for you to try to fix this as TV's run on high voltage and you could kill yourself.
If you really cannot find a tech to check it for you the only thing you can try is to check for a broken fuse.
You Must Take Great Caution.
If you are a person that like to take things apart you may try to take the back off .
Start by disconnect the power cable and follow the main power cable inside , normally it goes where the main switch is located and there you should find a Time Fuse normally the value is around 2.5 amps T for time it should say on circuit board & on fuse.Check for a faulty fuse.If faulty replace with the same type fuse and before you plug it in put back all covers than you may try to put on TV.
If fuse is good than fit back cover and take to a professional.
Nov 29, 2007 | Sony KV-27V55 27" TV
No Sound, No Picture
loose connection inside i would check the convergence amp area.
Convergence amp ic bad
Sony Convergence
Sep 23, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Televison & Video Logo
186 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
