Question about SanDisk Sansa e260 MP3 Player
Sansa Wont Connect to the Computer
I plugged in my Sansa to the computor but the computor doesn't even recognize that there is something in the USB port. It's not the USB port itself, other components work. Not only does the computor not recognize it but my Sansa is also out of power to turn on so I can't charge it. Help please!
  • Swilli72 Jun 10, 2008
    My computer does not see the MP3... my ports are good. What do I do?
  • STYMIEDBIG Jun 10, 2008
    MINE WILL RECHARGE BUT WON-T BE RECOGNIZED?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Computor doesn't recognize it from usb cable I have an Hipstreet HS m701 4GB and when i plug in the usb cable the computor does not recognize it
Hi, Mine did not at first either. So I tried the ac plug in and it began to charge. Then I tried the computer again then it found it and installed the driver. Works now.
Sep 18, 2011 | Computers & Internet
My sanddisk won't connect to my computer what do i do?
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
Jun 26, 2010 | SanDisk Sansa e250 MP3 Player
Usb is not recognizing sansa
try going to "my computer" on your desktop and it should show an unkown device thats plugged into one of your drives
Aug 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Computer wont recognize Sansa Mp3
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jul 19, 2009 | SanDisk Sansa e250 MP3 Player
Cannot get my computer to recognize my sansa e260 player
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
May 01, 2009 | SanDisk Sansa Connect MP3 Player
Sansa e260 does not get recognized by coputer
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Then connect to your computer and see if it works
Hope it does..........Please rate
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
Does not recognize
The dinging sound is the USB port telling Windows that a device is connected, and does not necessarily mean that Windows recognizes a device.
Are you using Windows Media Player 10 or higher?
May 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa media converter will not recognize my mp3 player
The Media Converter will only recognize the device in MSC mode.
Make sure it is on this mode and try all of the USB ports on your PC. If that doesnt work, try uninstalling and re-installing the Media Converter.
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e260 MP3 Player
Can't connect!
Has to be Windows XP for either USB Mode but im not sure whether u can connect it to other computers under different versions of Windows or not and I know Apple computers dont work at all with the Sansa E200 series. Also connect ur Sansa to the rear USB inputs instead of the front inputs. Something that has to do with power distribution if none of these call their tech support they were very helpful with my issue.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
