Question about Palm Tungsten E2 Handheld
Still need ur help
Thx so much for ur immediate response, i followed the steps as u stated but the "palm powered" logo didnt come up not until ik release both the power n reset buttons.Please is there any other method.Thx again
    Novelist:
  • 153 Answers
not as far as I know I don't have an e2 (just an older palm) but I did check the E2 manual and the instructions were the same.
With mine there is a bit of a knack to timing it right.
If its like mine you hold the power button and keep holding it while you press and release the reset button while still holding the power button until the logo comes up then release the power button. You also need a good charge in the battery.
Give it another go and I will have a look around the forums to see if there is another way or any tips...
Posted on Jun 10, 2008
My IPhone has frozen and I can't even shut it down. Can you help me with this problem?
you can try the following steps
  1. Press and hold the Sleep/Wake button until the red slider appears. When you see the red slider appears, release the Sleep/Wake button.
  2. then press and hold the Home button for six seconds
if the screen is still unresponsive try to restart the iphone by following these steps
  1. To turn the unit off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn the iphone on, press and hold the Sleep/Wake button until the Apple logo appears.
if restarting does not work, try resetting the iphone
1. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds or until you see the apple logo appears
if your screen becomes responsive, try to reset the settings by going to the settings of y ur iphone then general then reset and reset all. after this, restore the files on your iphone through itunes
Apr 20, 2011 | Apple Cell Phones
After a hard reset (reinstall battery while holding down the end key) I receive the ACCESS Powered screen. When I let the end key go I receive the prompt to delete all data. I key the up arrow and the...
Hi there if you can access the manufacturer website you should download the software available for your device, this should solve the problem.Simply go to the website and look for your model of palm and follow the steps.
Jul 06, 2010 | Palm Treo 755p Smartphone
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
I have an black one and everytime I turn it on its asking for an password and I don't know it
Hello guccimane04,
A hard reset will unlock the Palm Centro But it will ERASE ALL of your data. If you choose to do a hard reset, the following procedure will work:
• Remove the battery cover on the back of the Palm Centro
• Remove the battery for a few minutes
• Press the power button when Reinserting the battery
• Release the power button after the Palm logo displays on the screen
* The hard reset erases all your data ! (Run a hotsync to retore the data) *
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 20, 2010 | AT&T Palm Centro Cell Phone - White
Can't use touchscrren - i've don't soft resets - no luck cleaned the screen won't calibrate
Try doing a hard reset. To do this you can follow these steps:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. Best wishes....Hope this helps.
Sep 16, 2009 | Palm Z22 Handheld
How to do a hard reset on a palm z22?
Hi here are the steps but ensure to backup data before you make a hard reset
While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
Wait for the Palm Powered™logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your handheld, do one of the following:• Press Up on the 5-way navigator to finish the reset and show the touchscreen.• Press any other button to do a soft reset.
When prompted, tap to align the screen, and then select the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar.
When the Welcome screenappears, the hard reset iscomplete
Hope this helps and do let me know
Mar 07, 2009 | Palm Z22 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Palm Z22
Just had to do a hard reset myself and it's not straight forward! While holding down the power button, BRIEFLY press the reset button on the back of the palm. DO NOT RELEASE the POWER button until you see the GRAY screen with the Palm logo (not the first screen with the palm logo). That should start the hard reset for you.
Aug 19, 2007 | Palm Z22 Handheld
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
