Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 washer not drying the cloths
My HE3 washer runs its entire cycle but the cloths come out dripping wet. No error messages come up. Does seem to make some noise when the tub initially moves.
  • 3 Answers
I had this problem a few months ago and it turned out to be a bad water pump; I replaced it myself and it was incredibly easy. The hardest part was removing the front panel, below the door because the screws are under a lip, about half an inch off the ground. When you get it off, the pump mechanism will be right in front of you. The pump is on the right side of the mechanism and is screwed into the plastic part. When I removed it, the impeller (a small, ribbed plastic part that spins and moves the water) was broken off from the motor. You can buy the whole pump mechanism from Sears for about $100 and install it yourself. Just follow the directions that come with it!!! Hope this helps.
Posted on Jun 17, 2008
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
HE3 DRYER
Clean all of the lint from the inside cabinet and duct work of your dryer. Then, try to clear the odor, by running a couple of loads of old rags or towels. Good luck!
Aug 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
79 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
